Flattop pistons
Old Jul 30, 2003 | 08:34 AM
You will probably get some noticable torque and horsepower increase. Somewhere in the range of 12 lbs of torque and 10hp at the wheels. The higher compression will also make better use of a performance cam should you go with one in the future. That will again boost your peak horsepower. The cam is a major drawback on the stock engine. But they put down some good torque at really low rpm.
Old Jul 30, 2003 | 07:17 PM
duckyz's Avatar
Now....I may be mistaken.....but didn't Datsun go with flat top pistons in '78?
Old Jul 31, 2003 | 12:35 PM
1981-83 non-turbo got the first flat tops in the L6. That is the point where they changed the block casting to the F54 block. Better cooling channels and a more rigid design for the 'brand new' turbo engine. They went ahead and used the same F54 block in the non-turbo and used flat tops in the n/a and dished in the turbo. (low compression for the turbo)
Basically 1975-80 engines are all the same. 170 crank hp and about 135 whp. Changing over to flat tops and using a closed chambered head in 1981 got about +10hp at the wheels and about 10 more lbs of torque. Of course with all the electric options going into the 280zx by that year the thing probably weighed 100 lbs more than most of the '79 and '80 models.
Old Jul 31, 2003 | 07:02 PM
duckyz's Avatar
I stand corrected.................thanx for the info!!
DoTheDrew888
Mar 9, 2005 12:39 PM
DoTheDrew888
Mar 7, 2005 07:09 PM
ZVOITURE
Dec 29, 2003 03:53 PM
awd92gsx
Apr 9, 2002 09:23 PM
Bob240z
May 17, 2001 05:42 PM
