engine stalls....
Old May 1, 2004 | 11:11 AM
lifegrddude's Avatar
Externally Wastegated
When you take the filler cap off, you're creating a massive vacuum leak. That's normal for the engine to stall. If it doesn't stall, then you'd have to worry.
John 82ZXT
Old May 3, 2004 | 02:46 AM
cerealkilla's Avatar
the l28 is equiped with an oil pressure safety switch. this helps by retarding the ignition when you loose oil press. it really helps when your driving down the road and you blow a seal and dump all your oil. it will kill the engine so you "shouldnt" seize your bearings. this does not work all the time. i know.
84z
Apr 12, 2014 06:50 PM
nerdbebo
May 22, 2008 11:45 AM
drisky
Oct 27, 2007 04:03 PM
venom8343
Oct 15, 2006 12:43 AM
buffet33
Mar 22, 2002 04:11 PM
