engine not running
Old Oct 28, 2003 | 01:38 PM
If you can smell fuel and she never fires, then most likely it is a spark issue. Might as well look into that first.
Check your distributor cap. Make sure its clean and dry in there. Have someone help you check a spark plug by removing it and holding the edge against the engine. With the wire still plugged in, have someone crank the engine over. Keep yourself insulated and away from the spark plug for safety. You should be able to see a small spark if not in direct sunlight.
Maybe the coil went out? Disconnect the tube between the air filter and the Air Flow Meter. This will allow the engine to breath good for testing. Also, disconnect the tube on the end of the throttle body. Open up the throttle with your hand and spray a good amount of starting fluid in there. Stick the boot back on and then crank the engine. Even if you have a super weak spark, it should fire at least a couple times before it dies again.... or maybe it'll start.
aaronsZ
Jun 2, 2013 06:41 PM
Zsomething
Jul 21, 2007 03:12 PM
BigEkak1941
Mar 1, 2005 04:46 PM
'76Z
14
Aug 4, 2004 08:58 PM
Driver300ZX
Nov 2, 2002 07:09 PM
