dumping fuel
Old Sep 15, 2004 | 11:05 PM
BgMJon's Avatar
dumping fuel
I just bought a ZX and its been sitting a while. so far i have replaced the AFM and some leaky fuel injectors. I cant get it to pass smog though. It is dumping fuel out of the tail pipe. Any suggestions?
Old Sep 16, 2004 | 07:00 AM
Phyxius's Avatar
Sounds like one or more cylinders arent firing. I'd check into your ignition system. Start at the plugs and work your way back throught the distributor and coil.
Old Sep 16, 2004 | 08:37 AM
You probably have a stuck fuel pressure regulator. Replace that and your oxygen sensor. Both are about $35 each and easy enough to replace yourself.
Then clean your spark plugs and try again. After the car is warmed up, let it idle for about 30 seconds. Then rev the engine a little. You should get minimal dark exhaust or maybe no dark exhaust. If you do, then you're still running too rich. If the exhaust is grey, then you're probably ready to go get another test.
MrStiggy
Feb 17, 2014 04:11 PM
RonK
Feb 11, 2013 08:48 PM
mrprofile
Jun 25, 2010 11:23 PM
tonsoffun300zx
May 16, 2008 08:10 AM
iriegirli
Sep 21, 2005 03:09 PM
