Digital Speedometer reads 0 ! help !
Old Jan 13, 2006 | 08:21 PM
3XAZOWNER's Avatar
I found a 83 Z with a good body, 109K, 5-speed, t-tops, new carpet and mats still in the box, needs clutch, a/c works, but the car would not start. I put plugs and plug wires in it and it fired up. But my problem is that the digital speedometer lights up but only reads 0. I looked on search but did not find anything. Are there any fuses, relays or speedometer parts that I can check myself ? Has anyone else had this problem? Any leads or suggestions would be helpful. I have stayed away from digital in my other 3 Z's, but the price was too good to pass up.
Old Jan 13, 2006 | 09:06 PM
duckyz's Avatar
Digital speedos are a big pain when they break. Check the cable from the tranny and make sure it's good before you start tearing it up.
Old Jan 13, 2006 | 11:10 PM
jfairladyz's Avatar
Yeah the cable is probably disconnected or damaged. If it's just sitting at zero then it's probably just not getting a signal.
Old May 6, 2006 | 01:45 PM
3XAZOWNER's Avatar
Digital Speedometer Broken
Is this the same cable that controls the odometer? , because the odometer works, but I just don't get any reading on my speedometer, just says "O".
Where does the reading come from? or what can I check? Is there a gear behind the dash or something digital that needs replacing? Thanks!
Old May 6, 2006 | 10:28 PM
duckyz's Avatar
There's actually some kind of infa-red sensor and wheel back there. I read a post somewhere awhile back on how to fix the 85mph limit on the disco dash.
If anyone has a link to that there's acutally a ton of info on the digital dash, how it works and what to look for if it breaks.
Z92AL
Apr 11, 2013 10:39 PM
Pipsqueak
Jul 9, 2012 04:15 PM
71OLDS
Apr 25, 2012 05:53 PM
Sp4rt4n
Feb 25, 2006 12:52 PM
dolcevita09
Jun 2, 2005 08:17 AM
