ZDriver.com
-   -   Computer Chip (https://www.zdriver.com/forums/280zx-performance-technical-79/computer-chip-9666/)
rupert42 Jul 7, 2004 06:21 PM
Computer Chip
were can i find computer chips for my 280zx the one that goes in the dash
AnTman86Tn82ZX Jul 8, 2004 06:50 AM
Try junkyards, ebay, classifieds.. etc etc
Bleach Jul 8, 2004 08:37 AM
Do you want a replacement factory fuel injection ECU or are you looking for a re-programed performance ECU? They never made them for the non-turbo 280zx. (I think) But they are available for the 280zx turbo, zcarparts.com
FastZ Jul 10, 2004 11:09 AM
What can you do for the non-turbo then? Cause I would like to know myself.
duckyz Jul 10, 2004 08:33 PM
Meeee tooooo!!!!!!!
Bleach Jul 11, 2004 12:32 AM
umm... almost nothing. I think they cost the same if they do reprogram them. $600 for +8-10hp? They flow enough fuel, its just that you need bigger intake ports in the head and a longer duration cam. Don't worry so much about the ECU. If you want a programable ECU, build a MegaSquirt unit.
FastZ Jul 13, 2004 08:39 AM
I think I see what you are saying. Get more air into the cylinder and then the computer will balance out the air through the oxygen sensor, right. What about a bigger throttle body and afm? Or what about a mass air sensor(I think that is what it is called, of a 300zx)? Would that be better? Also what duration cam would be good?
Skully Jul 13, 2004 07:38 PM
i got a bigger afm and all the piping and a bigger TB of a 240sx and then just adjussted the AFM for "proper" mixture, i got a bigger exhaust...i dont notice any power off the line...but the high range is better....but i have a cheap version of "KN"(fake) filter on, really small too.... I had to move on a sunday and everything was closed so i bought that, maybe if i changed that it will improve it more even...
i say go for the larger AFM and larger TB, I have nother large TB but without TPS...i dunno if its of any use
Bleach Jul 14, 2004 07:44 AM
Originally Posted by Skully
...I have nother large TB but without TPS...i dunno if its of any use
Ya, I see those for sale on eBay all the time. Did you get tricked into buying it or did you just pick it up at a wrecking yard?
If you look at dyno sheets that have air/fuel readings almost all 2-valve engines (including the L28) run rich at high rpms where the power drops off. The limiting factor seems to be the cam. The cam is ground in such a way that you have good torque right off idle and good power through 5000 rpm. Your average driver never goes over 3500rpm anyway. (maybe not average for a sports car driver) A longer duration cam with high lift will get more air into the cylinder at those higher rpms and porting out the intake ports and possibly the intake manifold will help a lot too. With the same amount of fuel being meterd you will have a lot more power because you'll have a cleaner burn and higher compression. (less of a vaccume)
I've heard arguments about weather the larger throttle body is nessisary or not. In theory it sounds like a good upgrade as long as you port match the connection on the intake manifold. I put one on and didn't do any other work... and well, its useless. But I got lazy and ran out of money after that. :D
Also, MegaSquirt fuel injection does not use an air flow meter.
A good cam is 450 lift and 280 duration
Skully Jul 16, 2004 12:23 PM
i ported...i read an article about if you dont port its actualy worse than the stock TB....
Bleach Jul 16, 2004 12:53 PM
:D I wouldn't doubt that! :rolleyes:
I plan to go back to the stock throttle body. That'll put me back at the smooth throttle response right off idle.
