Colorado???
anyone live in colorado? i'm moving there and was wondering if anyone knows the emission and safety laws for this car or this old of a car??what do i need to make sure it will pass?
I just moved from there and hopefully can give you some helpful info.
Colorado does not any safety laws or "vehicle inspections" you need to do. Emissions testing varies from county to county. I.E. Colorado Springs - unless it's a diesel it doesn't get emissions tested. Denver - you do have to get emissions. Odds are you'll also have to have your VIN verified to make sure it matches your title coming from another state. But that may be only if you bought the car in another state - I don't remember. If you do, you can go to a police station in your county and they should be able to do a VIN verification for free. Otherwise it will probably cost anywhere from $10-20 at a dealership or emissions testing center. Hope that helps. |
ok so i have an exhaust leak at the manifold gasket. i assume i HAVE to fix this before i drive 2k miles. is there anything i need to check before i drive from North carolina to denver? brakes...check, lights..check, tires...check, burns a little oil..., clutch...check, new plugs and wires...check, fresh oil...check, thermostat...gauge runs hot but i dont hear boiling...pull thermostat out for trip, re-grease undercarriage... in process, anything else?
well I live IN wyoming bout 4 hours away from denver well have to meet up when u get here and check out eachothers 280zx's :) im in the middle of putting a new l28 in it atm mines blown :/
