BUYING TURBO STUFF..help
Hey im starting to buy everything for my turbo swap and was wondering if it matters if i get a turbo ecu from an auto or manual trans? I HAVE AUTO RIGHT NOW AND AM GOING TO five speed after the turbo swap. Will an ecu from an auto work with one thats manual? i would figure that it wouldnt matter beings that the car uses the vacuum to tell it when to shift but just in case. Also, i have a basic setup up and am aiming to drift and my hp goal area is 350-400hp. some ideas of what turbo to get and wat trim and stuff would be appreciated.
auto
10 char |
No... auto / manual doesn't matter for the turbo ecu. And seriously ponder finding a complete L28ET before spending twice as much time and money trying to piece it all together. :D
anything above 300WHP will either require some serious money or an engine swap. IMHO you can buy a new sbc crate motor with a warranty and get the same HP if not more for about half the cost of building an L-series motor to the same level.
Originally Posted by WildmaN
Unless you know what you are looking for. And what you want to do. And you want to make it a learning experience. Which in my case...describes what I am doing. Also when it is difficult to find a turbo out here. ;) The Z yard, wanted flippin' $750 just for the block. That is friggin' crazy if you ask me. By the time I would be done, I would have been spending $4-$5k or more on my turbo conversion.
http://cgi.ebay.com/ebaymotors/Nissa...spagenameZWDVW http://i9.ebayimg.com/01/i/000/d4/57/4a39_1.JPG |
I see complete L28ET's quite a bit on ebay... usually go for $300-$500 + $200-$500 freight. This one you coulda almost driven to & picked up:
ill garuntee you could haul that in your Z. woulda had to lay it down, but these block honestly only weigh aboot 200 lbs. ive picked one up before on my own. well, that actualyl was a stripped block. but still just add another 100 lbs and call it even
ok cool thanks. i kinda want a sbc but wont get that satifaction of building a straight six first. I know i can get mass amounts of power from an sbc but i want to test myself with the l28. i was thinking buying the distributor, ecu, oil pump, oil pan, oil lines and stuff then buy a hybrid t3/t4 turbo. and everyone already knows i have turbo injectors already haha.
turbo fuel rail is diff, same with the oil pump shaft, also the ecu harness and you need a way to plumb it, and a turbo AFM and exhaust manifold and down pipe and exhaust and TPS (though not needed still different the na one works though) plus changning the dizzy, oil pump & shaft you need to set it all in write for the proper timing to be achievable, and then actually time it. its alot of work. plus you need to wire it all up.
ya all that stuff to. but im not really worried about it. should actually be pretty easy.
easy.... not at all. hard? meh, challenging and time consuming. but by no means "easy". my swap gave me problems for months till i finally got it all worked out. mostly wiring issues, initially timing issues. also dead ecu issues. used parts are hit or miss unfortunatly, and i got a ECU that was on its way out. also, for all these parts fast, search EVERY listing in teh parts classified section on
zcar.com and classiczcars.com i was just browsing through and they got EVERY part to do a complete turbo conversion. |
