Bung Adapters for Z31 ECU
Subscribe
Oct 13, 2011 | 07:58 AM
I don't know if anyone has seen these before, but I ordered this: http://www.amazon.com/Drag-Specialti.../dp/B0031BIU6G
It's supposed to be a bung adapter which can downsize the 18mm O2 sensor to the smaller 12mm Zirconia sensor. This would make life much easier for anyone doing a swap to the 86+ Z31T ECUs. I found the 86+ ECUs to be much better with the cold-warm transition, and to just be overall smoother. I currently run an 88 N/A ECU so I can use the larger 18mm style O2 sensor, but I also have an 86' Turbo ECU and this will come in handy should I need to switch to it as I could run that corresponding O2 sensor.
Reply
Mar 2, 2013 | 02:12 PM
sorry to bring up an old thread, but has this worked for anyone?
Reply
Subscribe
