Boring recommendations
So here's my wear on the engine that I'm rebuilding.
Standard is 86.000 mm and here's what I have Cylinders 1,2,3,5 and 6 are mic'd at 86.0425 and cylinder 4 is 86.0679 with the maximum wear being 86.1mm. What bore recommendations do you have for me, considering I need to buy new pistons and rings now that I destroyed my previous ones. Would a .5 mm overbore be too much? I'm going to buy ITM's pistons from a distributor right by my school. As for the boring and honing I might have a machine shop do the boring, or I might take a crack at it myself. Any tips or recommendations? |
(Post 268568)
My point of view is to go 1mm overbore for two reasons: #1: If you are going bigger, GO BIG... not just "kinda big". #2: .5mm (.020) rings are (or at least used to be) hard to find. |
if your gonna bore and have to get new pistons might as well go out to 89mm
itl make it a 2.9L (get a diesel crank and 9mm rods and youve got yourself a 3.1L stroker:biggrin:) |
^^^ lulz.
Great minds..... |
(Post 268575)
^^^ lulz.
Great minds..... and compared to an 86.5/87mm bore itl be easier to get pistons and rings too 89mm = KA24 :023: |
Is this going turbo, or are you just going to run it N/A?
KA has so many aftermarket for it it's nuts. 'If they don't make for your engine. make your engine for them"
Originally Posted by duowing
(Post 268579)
(Post 268585)
Second rebuild on his L28ET in his S30.
I've decided to go with .003" oversized from ITM obviously I have to bore it out, so should I bore it to .0028 and leave some for the hone? Or maybe .0026. Thoughts....ideas....experiences? i'm all eyes |
dose that first one really count.... :037:
(Post 268604)
(Post 268604)
if only i could find the pistons i need. that's the largist part of my build. pistons.
(Post 268664)
check your PM's
well ITM doesn't have my pistons, they CARRY the standard, .02, .03, and .04 but NONE are in stock....
L31et? sounds really FRIGGIN hard |
(Post 268681)
L31et?
(Post 268681)
Have you called Nissan? |
| All times are GMT -7. The time now is 12:43 AM. |
