backfires while driving
Old Mar 26, 2010 | 09:13 AM
kennyscomp's Avatar
I have an issue while driving my 83 Turbo 280ZX, it will run great, starts great but out of the blue it will start to die while cruzing or excellerating. when I tire to keep it running I have to pump and get on the trottle.
I changed fuel pump, injectors, fuel press regulator, Air flow Meter... all with no help. I'm tired of putting more money into it, but will take it to a local shop for help if I can't find anything out here. All your help is greatly appreciated and I can fix almost anything myself with some help! thanks again. Kenny G
Old Mar 26, 2010 | 10:48 AM
vitaminZ's Avatar
From the top of my head while it would be backfiring..bad distributor cap, bad spark plugs, bad timing,plugs..mmmm I'd check the plugs first.
Old Mar 26, 2010 | 10:09 PM
lifegrddude's Avatar
Externally Wastegated
Sounds like the start of either the ignition module going bad, or the coil. Check those out if you haven't yet.
Old Mar 27, 2010 | 08:54 AM
kennyscomp's Avatar
thanks for the help! i will let everybody know how i make out.... please keep sending me the suggestions
Old Mar 27, 2010 | 07:25 PM
Also check all sensor connections for corrosion (TPS, AFM, CHTS). And check your ecu plugs.
I spent about a year racking my brain on why my 280zxt would "miss", "studder", and sometimes just "go wacky". Come to find out the 2 ground wires on the bottom most ecu plug were faulty. Those 2 grounds are the grounds for all the major EFI sensors, so the whole system was going wacky, then back to normal when those wires moved. I ended up cutting that whole plug out, redoing the grounds, and splicing in a Z31 ecu connector.
I've got a thread about that... it's called "The Bitter End".
87zxt
Dec 16, 2012 12:05 PM
280zx2by2
Dec 3, 2008 04:12 AM
Ace Conductor
Jun 8, 2008 02:56 AM
fdc_guy
Apr 27, 2005 03:03 PM
jesusfreakz
Sep 28, 2002 10:38 AM
