Anyone heard of a Z with a 4-pin Ignition Switch?...
So I am trying to get the Z started and its turning over normally then starts but as soon as I let the key return to "run"...the car dies. This happened consistently and, among other things I was checking, I noted that when the key was at the point in ignition switch that should be the RUN stage (i.e, lock - acc - on - RUN - start) there were no idiot lights on any longer, as in, there is a dead spot at RUN....the lights are there at the ON point.
So anyway, long story short. I replaced the switch with a new one thinking the other one was damaged. Problem, however, persisted. I then checked the harness plug for the switch and found it to be a 4 - pin plug. No connector for the pin that represents the RUN pin on the ignition switch. No wonder I was getting dead signal at that point. So I have checked with the usual vendors and everyone seems to have only one ignition switch listed as replacement, I assume, being the 5-pin switch. They can not confirm as they do not have the part in hand. So my question is out to everyone. Do you know of the existance of a 4-pin switch for the Z? Mine is a 78, presumably with its original harness. If so any ideas where to get one? what the part number may be? Anyone have access to a parts fiche? Any help would be appreciated before I start digging for a fault. It might just be a missing wire from that harness plug....but I didn't see one loose and dangling anywhere. |
hmmm, did the pin fall out? mine has 5 pins, 3 up one side 2 on the other side of it.... all the one i know of are like that to.
Yeah, let me clarify myself here...my current switch itself has 5 pins on it, exactly as snw said. Its the car's switch harness plug itself that has only 4 connectors, that those switch pins go into.
So ultimately, there aren't enough harness plug connectors that match up to all the pins in the switch. |
So seems like the 78 280Z actually had a 4 - pin ignition switch.
http://www.hammondsplains.com/newtec...80z_wiring.pdf For those of us that need it, The link above has the wiring diagram for the 78 280Z. The ignition switch is shown as a 4 - pin hook up. (circuit drawing to be found along the bottom edge approximately halfway across the diagram). I guess now I have to find a 4 - pin switch so I can start it. |
thats interesting, sooo is your harness connector laid out the way in teh diagram? did you ever change teh ignition before it ran? just because its a 5 pin ignition but the 4 pin harness doesnt mean thats the problem.... if the wire is in teh right place when the key is at that spot thats all that matters, you might just have to move a wire.... its technically just a way to bridge teh power nothing special about it....
snw...thats exactly what my thought process was...and I did try to "bridge" the connection but nada luck so far.
As I mentioned in the first thread, there is no connector within the harness for the "RUN" pin and thats why there is a dead spot in the ignition process at that stage. The car starts but turns off as soon as I let the key go back from the start stage to the run stage. Basically, as far as I can tell thus far, I need a 4 - pin switch. In the meantime, I will just have to invest a bit more time before I can make an improvised connection work for me. Thanks for your thoughts. |
you know i am kinda a wiring guru, i bet there is a way to make it work, you either need power to it, ground, or power leaving it. just need to splice into the harness and take the correct power to make it work, or pay 250 bux from abbotsford nissan and get the all new lock set.
well, for kicks, you should toss up a pic of YOUR plug and back of ignition.... this interests me
am i the only one that picked up on this being an S30 issue in the S130 section?
No this post wasnt helpful, but I'm sure havin an S30 owner that may have had to rewire to accomodate a a 5-prong ign. sw. actually read this thread could be ;) |
If this is a 280z, did anyone check the microswitch in the air flow meter?
Ok gentlemen,
As per snw's request, below are the pics I just took.... As you can see that the ignition switch has 5 pins as are usual...I have two others exactly alike, one that I had from before and another that I bought because I thought both of the older ones may be at fault. http://i160.photobucket.com/albums/t...012resized.jpg Here is the ignition harness plug, showing 4 connectors, two plug holes, or whatever they are called, are empty. http://i160.photobucket.com/albums/t...ug-resized.jpg Here is the harness plug in relation to the overall wires under the dash. Note that the wires going into the plug are the same colours as those mentioned on the 78 280Z wiring diagram, the link is below. http://i160.photobucket.com/albums/t...ss-resized.jpg http://atlanticz.ca/zclub/techtips/w...80Z_wiring.gif Shady, I think the splice connection may end up being my only option as most salespeople I talk to think I am nuts. I am now second guessing myself even though a wiring diagram from a reliable source - AtlanticZ - confirms the existence of a 4 pin harness plug. i.e, in the absence of a 4 - pin switch...thats the closest I can come to a conclusion. Maybe I can rig up a push button ignition with a password protected keypad, much like this other guy on Hybridz. click the link below http://s140.photobucket.com/albums/r...esworthy/240Z/ ...and J, I posted the thread on the S130 forums because I know you guys and you guys are always helpful...so that explains that... Now for the last but not the least..."micro switch" on the AFM, huh? a little more of an explanation please...I have seen snw mention it before in another thread and it may be applicable if the fault is not with the ignition switch but I dont know what the conenction to be made here is with the missing wire in the harness plug? |
hmmm, when i mentiont eh AFM problem (idk if this is the micro switch i explian) it basically if the connection is bad or the AFM isnt hooked up somethign wrong in it blah blah blah, the fuel pump wont turn on, that will be for start up as well though i do believe.... i basically only mention it when people say my fuel pump wont turn on and stuff.
So are you sure your original ignition sw. was the problem to begin with? This could be a wiring issue and not the fault of the sw. itself.
If the microswitch in the airflow meter is bad, the car will start and shut off soon after you release the key.
I've seen hundreds of them in the last 19 years of Z car service. |
its like fitting a square peg in a round hole, if the harness has 4 pins, the switch aint gonna work. something tells me its the wrong switch, are the older switches 4 pin? ill check me old 75 truck and see how many pins it has, then we can test with that.
I've seen hundreds of them in the last 19 years of Z car service. I assume by not addressing the ignition switch as a fault, you are saying that there is no 4 - pin ignition switch in Z-cars, more specifically a 78 280Z. Considering your years of expereince with the Z cars, what are your thoughts on the wiring diagram that shows a 4 wire harness plug?
I agree Shady! what I am attempting to figure out if my 78 Z needs to have a 4 - pin switch. So if you want to check then its all good with me. Coincidentally, have you looked at the wiring diagram for the 78 Z? I posted the link earlier within this thread. The ignition switch is depicted on the bottom of the diagram, about halfway in the middle. Its super small initially when you open it up, but will magnify a particular area, if you click on it. Thanks dude. By the way, Nice car! now that I finally got to see it for myself. You truly are a wiring guru! |
I'll check my 1978 wiring diagram.
Here, save yourself some trouble and get the correct ignition switch, page 70, upper left corner of the Black Dragon Automotive Catalog, Thats part #71-680 price $109.95 ......here is a pic:
http://i26.photobucket.com/albums/c140/mwh5150/0070.jpg |
well... in there they list teh ignition 70-78 the same... soooo does that tell you something? and i asked my dad today, he doesnt remmeber on his Z but he said he pulled a 5 pn ignition off a 78Z from teh junk yard a couple weeks ago. sooooo... idk gravey
thxone, thanks, although I know black dragon has those parts for sale and actually the part I would need is listed at $19.99 being just the electrical switch. I dont need the whole ignition. The problem is that they dont specify if they have a 4-pin switch or not. I called them and the order person, however very polite and cordial did not have the answer either.
They only take the part orders and do not have the parts there to confirm anything....but thanks anyway... snw...thanks for checking with your dad, dude.... now, I dont know about anyone else, but lets just let this thread die...its dying already, but it real slow and painful! I have had it with this damn switch issue. I am fully planning on going with a keypad ignition. I'll let you all know what ever my research turns up. Thanks muchly to all who cared! |
dude call mike boles (dr. z) hes gotta have a switch that will fit directly in.
