air intake problems
Old Jun 25, 2003 | 01:59 AM
Fredrik's Avatar
Give the man a break. I think it´s kind of cool with low-budget solutions. Learning by doing!
Old Jun 25, 2003 | 06:41 AM
lifegrddude's Avatar
Externally Wastegated
Is the backfire from the intake or exhaust? Is it sputtering and causing bad driveability? If it's just a slight "putt" sound in the exhaust don't worry, free flowing mufflers and intakes will make the car putt on occassion. Happened to every car I've owned. I think it's normal. But if it causes problems then yeah it's probably a leak. Custom intakes on a low budget are awesome too. It'd be easier if companies did make stuff for the Z's, but they're so old that they don't see them as a good market anymore. Custom is the way to go!
John 82ZXT
Old Jun 25, 2003 | 07:37 AM
Ok, whatever. A curved PVC pipe vs. the $100 powdercoated metal pipe I bought from Motorsport do exactly the same thing: Hold a K&N filter. There is no research or development in the intake piping, although I wouldn't go too large of a diameter if you're using the factory air flow meter.
An air leak will only effect your engine if it is after the air flow meter. The pipe you put on will not bother the mixture. Check the connections between the meter and the throtle body and all the hoses that plug into that housing.
McVick
Apr 13, 2010 11:55 AM
280ZX_AV8R
Jun 17, 2005 06:47 PM
'76Z
Dec 14, 2003 04:35 PM
madzracer
Aug 23, 2003 11:46 AM
thomas schuchat
Apr 17, 2003 11:26 AM
