AFM adjustment screws
Old Jul 23, 2005 | 10:28 AM
Denzil's Avatar
The AFM on my N/A 280ZX has 2 air bypass screws, one on either side. Which one do I use to adjust the CO. All the books and references I have only show one screw. Any ideas?
Old Jul 23, 2005 | 11:47 AM
What is the problem? Can't pass emissions?
I would usually say to leave the AFM adjustments alone. If the AFM is messed up, replace it. First check other areas to fix mixture problems. Have you replaced the oxygen sensor yet? Only $30 or so...
Old Jul 24, 2005 | 09:04 AM
Denzil's Avatar
No emmision control in South Africa. S/African 280ZX's don't have O2 sensors. I wanted to make sure the car was in "tune", as I moved it from about 5500ft above sealevel to the coast.
Old Jul 24, 2005 | 09:47 AM
duckyz's Avatar
If you drive it to the coast, you should be ok. If you tow it, you may encounter a problem...not likely since your dropping elevation. It's going back up where you'll have fits.
aburton
Jun 8, 2009 09:05 AM
aburton
Jun 2, 2009 01:42 PM
mike88se
FS: 300ZX (84-89)
Mar 1, 2009 05:33 PM
Blue_streak
Jul 9, 2008 08:02 AM
n00blar
Oct 20, 2007 10:07 AM
