81 280zx no turn signal flasher
Old Sep 24, 2013 | 05:29 PM
miamipammy's Avatar
Hi, I have hazards and the flasher is only connected to the hazard, but no turn signals. When I put the test light on the fuse for the turn signals it sparks and makes a clicking noise under the dash by the fuse box. I can't seem to see the flasher for the turn signals or even a connector. The p.o. really did a number on the wiring on my 81 280zx. Any help is greatly appreciated! Thank You, Pam
Oh and I do have hazards. All bulbs are good. Hazard switch is turned all the way off.
Old Sep 25, 2013 | 02:58 PM
miamipammy's Avatar
turn signal flashers
Well I fixed the turn signals. took apart the turn signal thing and cleaned it up
then turned the hazard switch off and on about 5 or 6 times and tada!
Old Sep 29, 2013 | 12:38 AM
mrprofile's Avatar
So a dirty connection caused the problem, if you didn't protect the connector in anyway then odds are the problem is going to happen again, put a little bit of vasoline between the connectors to protect the contacts from the elements.
gdcat51
Jun 27, 2009 12:15 AM
Speedwrench
Jun 5, 2009 07:13 AM
nismo619
Oct 1, 2005 08:07 AM
