4 Barrel Holley and Cartech intake
Old Nov 30, 2012 | 06:18 PM
cpark_12's Avatar
So, as many of you've read, I was having trouble with my F.I. system. I did figure out the problem: Bad wiring from the CHTS to the ECU, but I'd already found a carb and intake set up, so I went ahead and did the swap. I've always liked carbs over fuel injection anyway (less troubleshooting!). I got a Holley 390cfm carb on a cartech intake. I've done enough reading to know people don't like that setup. Anyway, I put everything together and got a little 4psi fuel pump. Fabricated a throttle cable and lever system and all I can say is WOW! This set up seriously blows the F.I. system out of the water and I don't even have it properly tuned yet. I've done enough comparison to state that. I don't know about fuel mileage yet, but I'll update that when I get a good average.
I'll get some more pics up, but this is the only one I have so far. The throttle isn't on in it yet and the bonnet and all isn't there either.
Old Dec 2, 2012 | 08:12 AM
A working carbed system should blow a nonfunctional EFI system out of the water lol.
Old Dec 2, 2012 | 04:47 PM
cpark_12's Avatar
True, but I finally got the F.I. system fixed before I did the swap. Turns out it was the wiring to the CHTS. I traced it and found a splice that wasn't connected properly, so i reran more wires a voila...damn good running car!
cpark_12
Nov 6, 2012 07:22 PM
FubarI33t
Jul 2, 2010 12:50 PM
KptClutchZ
Jun 10, 2010 12:51 PM
michanic220
Sep 16, 2008 10:26 PM
Mike Phillips
Oct 6, 2007 11:29 PM
