280zx - LS1 Engine Swap
Has anyone taken on this engine swap? I am about to begin and would appreciate any input.
Thanks ckrause333 |
Originally Posted by ckrause333
(Post 296791)
Thanks ckrause333 |
:D
https://www.zdriver.com/forums/280zx-brakes-wheels-suspension-chassis-81/81-280zx-improvement-s-29527/
(Post 269578)
Oh man, I'm only going to say this once on this thread...
Shoving a V8 in a 280zx really takes more planning and engineering than you think (to make it work right). The 280zx has a close to perfect 50/50 weight distribution. If you shove in a heavier motor farther back on the front cross member, you throw off the balance, and have to over-compensate in other areas to fix it. IMO it's not worth it at all to use any other motor than an inline 6 in the S130. If you are dying for a V8Z, get an S30 (240z-280z). And I'm done. :D |
LS 1 w/ t56
actually the LS 1 motor is lighter , all alum. had to lower my car , 1.5 front and 1 in. rear , after my swap to bring it back to its original height .
