Philbert |
12-12-2011 01:40 PM |
Glad you got it working - I had a smog nightmare a couple years ago and it failed 3 times before passing (I did cap/roter/wires/air filter/plugs/rewired all injectors and cold start, and finally a new cat did the trick after all that.
I recently went through this with my 87 4runner and it was failing with high NO - I cleaned the EGR and it failed again. I got a new cat, and it failed. Then I looked closely and realized the EGR vacuum tubing was not to spec - I had hoses going the wrong way and the EGR was not doing its job. Re did the hoses and BAM! passed with flying colors.
CA emissions are always a fun adventure.....
