240sx 60mm throttle body
Old Aug 29, 2003 | 12:35 PM
cerealkilla's Avatar
Question 240sx 60mm throttle body
hey guys, i have an 83 280zx and an now the proud owner of a
60mm tb. its the one off the 2.4 I-4 240SX, you know the one with JECS on the bottom? anyways it has wires coming out of the side of the tps and im wondering can i run this tb without these wires hooked up? i know that the tps housing connectors will hook right up to the stock tps wire bundle in the car. never done this b4 any thoughts?
Old Aug 29, 2003 | 12:42 PM
addition
also i have a turbo in a closet off a 2.0L ford probe that maxes at 14 psi. how much if any of this 14 should i run on a non-turbo engine?
Old Aug 29, 2003 | 12:44 PM
addition2
with stock internals?
Old Aug 29, 2003 | 01:24 PM
Only the early 240SX throttle off of the KA24E will work with the Z's throttle position switch. (12-valve engine, not DOHC 16 valve)
Also, I'd say 6psi and some way to increase fuel mixture.
Old Aug 30, 2003 | 02:23 PM
Skully's Avatar
yeah the 240sx came with 60 mm TB....
91-93 i think is the gen you want for the TB mod....
Old Aug 30, 2003 | 03:34 PM
Skully's Avatar
so your telling me all these people (including me) with 240sx TB swaps did all that work for nothing since its not a 60mm tb...
and so these people are lying?
http://search.ebay.com/search/search...240sx+throttle
Old Aug 31, 2003 | 01:57 PM
i know that this t/b is off a 240sx. 4 a fact, took it off my self and sure enough it is 60 mm. and i like it!!!!!!!
Old Aug 31, 2003 | 09:01 PM
lifegrddude's Avatar
Externally Wastegated
That turbo you have a pic of, it's going to be harder to mount to the ZX than a regular T3 out of a 280ZXT would be because the turbo you've got has a 2 bolt compressor inlet whereas the T3 of a 280ZXT has no bolts and is just a regular opening. And the outlet for the J-pipe on the turbo ZX wouldn't match up with the outlet of that turbo. But if you have a place to fabricate an exhaust manifold and intake pipe for you, I'd say you could push ~4-6 psi.
John 82ZXT
NismoPick
Nov 29, 2008 10:28 AM
KTM200-280zxt
Oct 19, 2006 11:37 AM
omniserv
27
Jul 13, 2006 06:54 AM
mescalinedreamz
Aug 1, 2003 06:17 PM
