1980 5 speed transmission problem!
Old Jul 17, 2012 | 10:16 PM
1980zx's Avatar
So I was driving home tonight on the highway and all was fine. then when i pulled up to the stop light my shifter was all whack! when i went to go into first it felt loose and when i let the clutch out i reved the engine and the car didnt go into gear. So now it wont go into first or second but i can still go to 3rd-R. Any ideas?? do i need a new trans?
Old Jul 17, 2012 | 10:23 PM
Start with a check of the fluid level in the clutch master reservoir.
If full, it may be the throw out bearing.
Old Jul 17, 2012 | 10:24 PM
1980zx's Avatar
how do I check that? Thanks
Old Jul 17, 2012 | 10:27 PM
Pop hood... look into engine bay... open clutch master reservoir cap... look into reservoir.
Maybe it's easier to start with this: XenonS130 - S130 Reference
Old Jul 17, 2012 | 10:52 PM
1980zx's Avatar
even when the car is off the stick just doesnt feel right. when i move it to first and second it just is real loose... it feels like its not even going into a gear like something disconnected. I dont think it has to do with the clutch..
Old Jul 18, 2012 | 01:19 AM
silverzxbullet's Avatar
seriously ^^ lmao switching gears doesnt feel right but nothing to do with the clutch hmmm....
Old Jul 18, 2012 | 04:27 AM
borini63's Avatar
maybe the shifter pin came out alignment and lost the C clip,in that case you still can go to third and fourth but not 1st,2nd,5th and revers!!!
Take off you middle consol and check under the inner boot.....just saying!!
Old Jul 18, 2012 | 09:20 AM
If you know your car is a five speed you should have the mental capacity to check the fluid level. If you can't check the fluid level of the clutch how do you check your oil level? If you can't/don't check your oil level......
You're new here but just so you know NismoPick is possibly one of the most knowledgeable guys regarding the S130 and willing to help out and patient like no one I've ever seen on ANY forum ever. So if you ask a question be respectful enough to take the advice of someone who knows what they are talking about - otherwise don't ask if you don't want to heed the advice. I don't mean to be harsh but put a little thought into it.
Old Jul 18, 2012 | 09:39 AM
icice9's Avatar
Super Siver & Black Stud
i don't think he was being disrespectful.. and i think borini63 might be right about the shifter pin popping out.. even if the car is off it should still go into gear without stepping on the clutch pedal.. and if it doesn't go into gear at all with the car turned off.. than maybe the shifter in fell out or worse case.. the trans is toast!
Old Jul 18, 2012 | 10:36 AM
1980zx's Avatar
hey calm down. At what point was I disrespectfull? If you dont have any advice or any help you dont need to post. Not to be harsh either but no one needs a D-bag.
Old Jul 18, 2012 | 10:41 AM
1980zx's Avatar
Yea I think you guys are probably right about the shifter pin. When I get home from work ill take apart the center console and see whats goin on.. I hope my trans isnt Toast! haha
Old Jul 18, 2012 | 03:37 PM
Philbert's Avatar
I had a sloppy shifter in my 1980 ZX (the shifter actually twisted easily counter clockwise, and clockwise in my hand....). Turned out the bushing in the linkage totally desintegrated. Really easy fix. Part is $6 from the dealer. I think I did a writeup on HybridZ with photos but I can't find it now....good luck!
Old Jul 18, 2012 | 03:58 PM
1980zx's Avatar
cool.. how did you get to the linkage??
Old Jul 19, 2012 | 01:20 PM
Philbert's Avatar
You remove the trim around the shifter...just be cautious and slow - the plastic is old and brittle. Unscrew the shift ****, pull the rubber boot off.
I think there are 2 screws under the "280ZX" plastic badge in front of the shifter - you need to first pop off that badge to access the screws...use a small flathead screwdriver, maybe with some tape on it so you don't scratch/break the badge.
I can't find the photos from when I did it, sorry.
There is a C clip holding the metal shaft that goes through the shift bushing - be careful not to lose it when removing it!
Old Jul 19, 2012 | 01:42 PM
Brass bushing install: http://www.atlanticz.ca/zclub/techti...ing/index.html
Old Jul 19, 2012 | 01:49 PM
Philbert's Avatar
Nice! This is similar to the job I did, but with the OEM bushings. The linkage looks familiar to the ZX. Just take time and move slow - it was my first time getting in there last year when I did it...made a world of difference in the shifter feel.
Old Jul 19, 2012 | 02:17 PM
1980zx's Avatar
So im in the garage I got everything off including the control lever. The control lever bushing seems fine. Im thinking it has something to do with the striking guide or the rod connected to the striking guide. any suggestions?
Old Jul 19, 2012 | 03:13 PM
1980zx's Avatar
and how the heck do you remove those stupid Eclamps??? I got the one off of the shifter rod but the one deeper down is impossable!
Old Jul 19, 2012 | 03:29 PM
Philbert's Avatar
Can you post some photos? I am not sure what you mean? There is one c clip that holds the rod through the bushings - you get that off, slide the rod out, then pull the shifter lever straight up (the bushings mount to the bottom of this piece).
Is there no play in the shifter? I had a lot of play, that's why I suggested looking at bushings.
Photos would help.
Old Jul 19, 2012 | 03:44 PM
1980zx's Avatar
ok ill post some pictures as soon as I can.. i was talking about a different c-clamp but i got it off. I dont think its the bushing... When you shift it into 1st or second its goes in the spot with no resistance but doesnt engage in gear at all.
Old Jul 20, 2012 | 12:17 AM
borini63's Avatar
A picker and a magnet!!!
Old Jul 20, 2012 | 09:33 AM
KC81ZX's Avatar
Sounds to me like a broken shift fork.... but thats just me...
Old Jul 20, 2012 | 11:00 AM
Could be the internal dog ears on the shift linkage theres three sets, 1 & 2, 3 & 4 then 5 & R
Old Jul 20, 2012 | 12:57 PM
1980zx's Avatar
yea thats what im thinkin too.. i might drop the trans soon
Old Jul 20, 2012 | 03:20 PM
1980zx's Avatar
quick question... is the linkage on the inside or outside of the trans.
koprutzxt
Aug 31, 2012 03:53 PM
jpape1224
Jun 26, 2011 12:19 AM
borini63
Aug 25, 2009 05:32 AM
79fairlady280
Jun 29, 2009 01:08 PM
BackHouseZ
Apr 30, 2008 05:57 PM
