1979 280zx <--> RWHP ????
Old Aug 19, 2003 | 08:57 PM
duckyz's Avatar
Well, I've heard a lot of different stories on this one...........
Seems like the stock RWHP is between 135 and 153, depending on who you talk to. I don't have any factory specs on this issue, so I can't verify.
Nissan (Datsun) likes to post main crank HP for some reason. You can take off about 10-15 HP from that and get a fair ballbark figure on how a perfectly stock L28 motor runs. Other Z's seem to vary more.........the new 350Z is posted @ 285 HP and dynos around 222 - 225 RWHP ---- stock.
If you REALLY want to know what you have.........spend the $$$ (about $40.00 here in Dallas) and get a dyno run. Some Nissan/Z clubs can get you a discount on a dyno run as well.
Hope this helps a little.
Old Aug 20, 2003 | 07:29 AM
The 280Z is listed at 170hp which is the crank power.
The listed hp for the 280zx 1979-80 is 135hp at the wheels and a well-tuned engine should get that kind of power. The later 81-83 280zx is 145hp at the wheels. Both have about 165-175lbs of torque at the wheels.
I've seen lots of 350Z dynos in the 240-245hp range at the wheels. With $5000 in bolt-ons you can get another 15hp!
Old Aug 22, 2003 | 12:13 PM
I really wouldn't say its that long of a stroke. My truck's L18 is almost exactly the same stroke and that thing redlines at 6500.
I think its all in the cam. You just put in a longer duration cam and make sure you have enough fuel in the upper rpm range.... then revv it to 7 grand. The L20b has a longer stroke than the L28 and it goes fine to 6000 rpm.
Old Aug 25, 2003 | 11:55 AM
Unless you got a different L28, I know the L20b is the only L-series with a taller block. The timing chain set/front cover is interchangable between the L16, L18, L24, L26, L28. The L20b has a taller front cover and longer timing chain to account for the taller block.
eZdoesit
Aug 18, 2012 07:14 AM
PowerhungryBill
Mar 20, 2008 09:56 PM
YellerZ
Aug 8, 2006 01:10 PM
DMacGeorge
Apr 4, 2006 05:28 AM
WhtFairLadyZ
19
Aug 1, 2005 07:18 PM
