Tokico Hp Assembled?
Well my stock shocks and struts on my 82 280zx are shot, i bought the car from an old man that never broke 35mph but now when i blast around a corner she sways back and forth so much i think im on an old pirate ship. Im looking at getting the Tokico HP Blue package off ebay for 330 with free shipping, but The guy that sells them wont email me back, Are they pre assembled or am I going to need to get a spring compressor? Thanks guys
ebay tokico hp
Well, thats where I got mine. Same price, the cheapest I found. Yes you need a strut spring compressor, not a coil spring compressor.
I tore a rotater cuff in my shoulder, and I had to pretty much supervise Fubar when we did mine. He had to do the more physical stuff, with help from Lee.
Maybe he will chime in? fubar?
You unbolt the fronts as an assembly. Once you get them out, you need to use a strut spring compressor
The front springs need to be compressed in order to disassemble the front struts.
You need a coupla large pipe wrenches to take the cap off the end of the tube. Then you take out the old cartridge, catching the damping oil inside the strut.
Clean out old oil and any debris in the strut tube. Pour some light oil, install gas strut assembly.
The oil you add is for heat transfer only as the Toiko is gas charged and not hydraulic. They do not come with front boots, you have to get those seperate. They are secured with zip ties top and bottom. the assembly is rotated, so the boots get kinked.
The rotors are new, just rusted before you know it. have to clean out from under fender and recoat. new brake lines, new bushings already done. Need to respray the strut where pipe wrench messed up the new paint.
Originally Posted by DATSUNSOCAL
I plan on changing everything not just the springs, looks like you just replaced the old springs? True?
for the rear you can get away with no compressor. leave the shocks assembled in the car, and undo the center not at the top. then jack up the car and they will decommpress themselves. if installing lowering springs they do not need to be compressed as they are very short. in fact they dont compress until the car is lowered. the tokiko strut is a good choice.
what you see in my post is what you get
The rears are easier to do.
As to the fronts, the struts are reused. You simply remove the stock contents, and replace with the Tokico insert.
The toughest part is doing the fronts.
Kit comes with 4 ( 2 HZ3038 front , and 2 HU2286 rear struts ) TOKICO HP Premium BLUE SHOCKS and 4( 2 front , 2 rear ) High performance Tokico lowering springs, not just the springs, thanks for help
dude, you don't listen.
some people just don't listen. others told you the same thing.
oh, and you are welcome, thats why I posted...to try and help you....?????
the best part about the kit is the warranty! I have the same kit on my z and i hit a big pot hole one day and bent my spring perch. I called tokico about it and they replaced it with a brand new one for free, no questions asked.
if you guys need any tokico give me a call. were on eBay and ill answer your emails...
iam a fellow z guy
here are some specials for the month of FEB
Dear Z car lovers and drivers.
Us here at Motorsports Direct would like to offer you guys a great deal on some products that we have to offer.
Everything is in stock, and if not we can still order it for you. As long as you purchase before the end of Feb. you Z guys get the special price….
To order just call
Anthony
anthony@motorsportsdirect.com
1-800-245-1001ph
702-245-1001 Canada
THIS IS ONLY FOR THE MONTH OF FEBUARY!!!!
SUSPENSION
Tokico suspension
Tokico Hp Shocks “blue”
$197.00 ALL S30 Z’s 1970-1983 (including zx model)
free shipping
Tokico Illumina Shocks “adjustable”
$382.00 ALL S30 Z’s 1970-1978
free shipping
Suspension Kits
Hp series kits (HP non adjustable blue shocks and springs 1” drop)
$322 + $12 shipping for 1970-1974 ½ hpk251
$345 + $12 shipping for 1974-1978 ½ hpk253
$322 + $12 shipping for 1979-1983 hpk255
Ilk Series kits (Illumina adjustable kits and springs 1” drop)
$470.00 ALL S30 Z’s 1970-1978 ilk252 & ilk254
FREE SHIPPING!!!!!!!!!!!!!!!
Koni Suspension
$500 + $10 shipping 1970-1975 240z 260z
Ground Control
$330.00 + $10 shipping 1974-1978
Russell Brake Lines
$82.50 1970-1983 686550 , 686600
ACT Clutches
$390 1974-1983 225mm non 2+2 & turbo
$280 1979-1983 240mm including 2+2 and turbo
FREE SHIPPING!!!
EVEN TO HAWAII, GUAM, CANADA OR PR!!!!!!
iam a fellow z guy
To order just call
Anthony
1-800-245-1001ph
702-245-1001 Canada
SUSPENSION
Tokico suspension
free shipping
free shipping
Suspension Kits
Koni Suspension
Ground Control
Russell Brake Lines
ACT Clutches
FREE SHIPPING!!!
DynamicJ
26
Aug 16, 2005 03:37 AM
benzz90
Dec 2, 2004 02:02 PM
