Taking out the rear subframe, where dem bolts?
Old May 6, 2012 | 01:19 PM
WanganDevilZ's Avatar
The Emblem Thief y0!
I have located six (Two for each of the mounts for the subframe, and then the big bolt itself that goes through the bushing) of the bolts that I know I need to undo, and then the six bolts that attach the struts to the towers, but what all other bolts are there so I can drop it out easy tonight
Old May 6, 2012 | 01:23 PM
You've got the major shtuffs. I would just leave the ebrake cable in place & detach it at the U coupler. Then just disconnect the brake lines from the calipers. Don't forget the drive line coupler bolts if the diff is coming out too. I believe you will also need to disconnect the left cv axle to clear the exhaust.
Old May 6, 2012 | 06:22 PM
The reason I'm dropping the rear sub frame is because I'm under the assumption that I need the turbo rear end to go with the turbo motor/T5
Why not take everything, and swap it over all at once?
Correct?
I'm prepping for a new Z in the garage
Old May 6, 2012 | 08:33 PM
Want or need?
You don't need the "turbo rear end". FYI, the turbo R200 is a 3.54 which is lower / slower gearing than the 3.9. The only benefit to the turbo rear end is the cv axles instead of half shafts.
I'm still running my 81 n/a rear end with half shafts and a CLSD 3.7 R200. I do have an 82 turbo rear end that I will throw in if I ever mangle my 81 (I'll do the camber cuts like PurePontiacKid), but since I'm still using the stock sub bushings, I doubt that will ever happen.
Old May 6, 2012 | 08:47 PM
Want or need?
So I'll be good with the N/A diff? I'll just need the Turbo driveshaft, aight?
How do you get the bolts off on the driveshaft, I've heard they're srs torqued on there
Old May 6, 2012 | 08:53 PM
Yup... no strength difference at all between the two diffs.
A combo wrench and someone sitting in the cockpit to put in in gear / out of gear so you can spin the shaft 4 times. That's all it takes.
Old May 6, 2012 | 09:00 PM
Currently, the trans and engine are out of the car, and the rear wheels are on ramps. =(
I'll figure it out
Old May 7, 2012 | 03:27 PM
I think the CV setup is worth swaping in... I believe you can take the guts out of the 3.9 and swap it into the 3.54 or swap the output flanges into the 3.54?
Old May 7, 2012 | 08:17 PM
I'll definitely be keeping everything except the chassis, nothing will be wasted
Old May 12, 2012 | 03:53 PM
don't let any body part be under the subframe when you finally undo the last bolt
safety first
Old May 12, 2012 | 05:40 PM
Oh, BTW... as one piece it's heavy as hell, so don't let it fall on you.
meanshyguy
FS: 300ZX (90-96)
Sep 21, 2014 09:59 AM
Champagne
FS: 300ZX (90-96)
May 4, 2011 09:19 AM
snwbrderphat540
15
Nov 27, 2007 01:11 PM
snwbrderphat540
Nov 21, 2007 07:27 PM
Z_Karma
Sep 18, 2002 06:51 AM
