Shake in Wheel. Any Ideas?
Old Sep 29, 2003 | 04:49 PM
Skully's Avatar
did you check your tie rods?
Old Sep 29, 2003 | 05:35 PM
icice9's Avatar
Super Siver & Black Stud
could be a few things... worn out wheel bearing.. but then youd hear it... iregular tire wear... or lopsided rim... or the guy that ballanced your wheel did a **** poor job at doing it... id bring it back to see if he did it right...
Old Sep 30, 2003 | 09:23 AM
I'm surprised you didnt' mention the brakes. A slight warp in the rotors can cause vibrations at certain speeds. Usually any vibrations on the front end are felt in the steering wheel a little.
Old Sep 30, 2003 | 06:20 PM
Jimmys83Z's Avatar
shakey wheels
you jack front tires off ground and support your Z, check for play in your bearings by lifting the tire and feeling it move.There should be slight movement, spin tire listen, should be smooth roll. If you think rim could be bent set bottle beside tire, spin tire and looking at gap between bottle and tire. If gap grows and shrinks a great deal then rim is bent, if gap remains same then rim is straight. You should also run hands around tires and feel for lumps..........
Old Oct 2, 2003 | 12:13 PM
Jimmys83Z's Avatar
luggs
I think what dudes talking about is like on mine as well. When I bought the car it had the wrong lugs on the factory rims. They were short shoulder luggs and should have been long. If this was the case that it was causing vibration you should be able to look at where the lugs contact the rims and see any damage they might have caused. The holes in your rim would no longer be round or would be beat out of shape..
Old Oct 27, 2003 | 05:11 PM
Skully's Avatar
yay i got something right! :P
Old Oct 28, 2003 | 08:02 AM
Lucky guess...
If its at the shop, how do you know that is the problem? After you pay them $238 to replace the tie rods there may still be a vibration, correct? But at least you'll have a tighter front end. Maybe it'll shake harder!
Old Oct 28, 2003 | 01:44 PM
Wow! So even if you still have a shake, its good you got those replaced now!
Cross your fingers. But if you can, I still say check those rotors...
Those wheels you have are the problem wheels. Even with the factory lug nuts, they'll sometimes bolt on off-center.
Take two accorn "steel wheel" lug nuts and gently bolt them on two opposing lugs. The tapered shape of the accorn lug nuts will center the wheel around the set of four bolts; even with a 1/32 inch of slop. Then tighten down two of your factory lug nuts on the two exposed bolts. Remove the accorn lug nuts and tighten down the other two factory lug nuts. Repeat on all four wheels. This bolts the wheel on as close to centered as is possible. I found that replacing my wheels (from the 6-star to aftermaket wheels) got rid of almost all of my steering wheel shake.
Old Oct 28, 2003 | 03:46 PM
Skully's Avatar
lucky guess...pfft bleach you know you wanna be me!
dont be hatin
Old Oct 29, 2003 | 08:18 AM
Excellent! One down, 485 things left to fix.
I've seen those tie rod ends priced at $60-90 each just for the part! I keep mine greased and with fresh boots on them to hopefully spare their life, and my bank account. Ok, I need to replace my rotors now.
Bleach does not envy Skully...
Old Nov 5, 2003 | 06:46 PM
duckyz's Avatar
Well, I'm glad you found and fixed the problem. I was going to say check the tire pressure, but...never mind.
Old Mar 2, 2004 | 10:34 AM
preith's Avatar
Nah then thats not the problem. I have factory rims and factory lugs...
I'm glad the problem has been resolved, but PintoZ had a good point. I used to do this all the time on my 1st gen with the same ZX rims and it works. The problem occurs with the factory lug nuts and rims because there's not a tight enough fit around the shank.
87z
Oct 8, 2011 07:47 PM
midwest83280z
Jul 10, 2010 07:32 PM
luckyZ13
Aug 4, 2008 02:55 PM
KasbeKZ
21
Jan 15, 2008 04:49 PM
