manual rack swap ?
Old Apr 21, 2012 | 10:08 AM
Tsuka89's Avatar
manual rack swap ?
Ok I want to swap in a manual rack in my 79 whats the deal with the crossmembers. Ive heard that the crossmember is the same for power steering and manual rack from 81-83? true?
Old Apr 21, 2012 | 05:24 PM
Aye true that... well as far as I know but then I haven't done a rack swap since my '83 NA already has the rack and pinion for the turbo swap... NismoPick?
Old Apr 21, 2012 | 06:25 PM
Can't say that I've ever compared a 79 manual rack cross member to an 81-83 power rack cross member. From Nissan4u.com the part#'s are different... dunno why.
http://nissan4u.com/parts/280zx/us_s...llustration_3/
Old Apr 21, 2012 | 07:46 PM
Tsuka89's Avatar
could they be the same because of recirculating ball powersteering or manual rack and pinion 79-80. and power rack and pinion and manual rack and pinion 81-83?
Old Apr 22, 2012 | 11:34 AM
I think they bolt in the same but the rack has more clearance needed for the turbo swap...
Old Apr 22, 2012 | 12:14 PM
Tsuka89's Avatar
could be... anyone else have any ideas?
Old Aug 6, 2012 | 04:57 PM
Tsuka89's Avatar
some thread revival, got my rebuilt 79 manual rack in today. I have a 81 power rack and pinion crossmember with the arm running from the coupler to the rack, what else do I need for the swap??, for those of you who have done it.
thanks guys
Old Aug 30, 2012 | 09:57 PM
Tsuka89's Avatar
rack swap
some thread revival, got my rebuilt 79 manual rack today. I have a 81 power rack and pinion crossmember off a turbo car with the steering arm, what else do I need for the swap?? or am I even in the ball park here? for those of you who have done it.
thanks guys
Old Aug 30, 2012 | 10:13 PM
Merged threads.
Today? Or a few weeks ago?
Bolt it on. I think PPK is running a manual rack?
Old Aug 30, 2012 | 10:22 PM
Tsuka89's Avatar
lol yep last week, cant get my mechanic to do the job (he has a 240z in his shop with bad headwork, can't seem to get rid of the thing) anyway; another question. will the manual rack work under a turbo engine(81)?
Old Aug 30, 2012 | 10:25 PM
Dude, all the cross members (79-83) are the same. Bolt it up.
FYI... all 280zxt's use the rack & pinion due to the proximity of the turbocharger to the steering column.
Old Aug 30, 2012 | 10:28 PM
Tsuka89's Avatar
thnx nismopick, knew the bit about the reasoning for the rack and pinion and turbo setup, hopefully will be done early next week, (better be I have autox weekend next weekend)
Old Sep 11, 2012 | 04:35 PM
Tsuka89's Avatar
ok bumping with another question, is the steering shaft the same length for the 81 power rack and for the 79 manual rack? I have nothing to measure against.
Old Sep 11, 2012 | 07:55 PM
I imagine it's the same... you could always go to nissan4u.com and look up the parts to compare.
I do know that the rack has a thinner rubber coupler compared to the recirc ball.
Old Sep 11, 2012 | 09:02 PM
Tsuka89's Avatar
bought new urethane coupler for the manual rack, will check the site
thanks
Old Sep 11, 2012 | 09:13 PM
Tsuka89's Avatar
date on the lower steering joint is listed July '78- for both '81 and '79 parts. and they are the same part number so it sounds like they are the same thing, couldnt get an answer out of zcarsource.com or msa. ZDRIVER.COM delivers the goods once again
Thanks
Old Sep 12, 2012 | 08:39 AM
According to PPK's FB pics, he's been converting a normal rack to manual rack. Or maybe it just asploded?
https://www.facebook.com/#!/photo.ph...type=3&theater
Old Sep 12, 2012 | 05:06 PM
Tsuka89's Avatar
has to be welded, I've seen it done on miatas all the time. In fact my friend just picked up a converted rack for his na miata
ITSZX
Mar 28, 2014 07:19 AM
Tsuka89
Oct 15, 2012 07:26 PM
mescalinedreamz
Apr 1, 2004 10:26 AM
dat240zg
May 22, 2002 04:30 AM
Bracem
Sep 23, 2001 05:07 PM
