HPK255's aren't coilovers...
Google result:
Tokico HPK255 strut/spring kit - has anyone used this setup? - HybridZ
Google result:
Quote:
Fronts - 200lbs
Rears - 175lbs
Originally Posted by FricFrac
Oh I did get the info for the spring rates for those who were wonderingFronts - 200lbs
Rears - 175lbs
I have them on my car already and know they aren't coilovers, I need a starting point so that I'm not too soft in the rear; ksports are 8kg/6kg F/R so they are underrated for the rear spring rate, so I'm going to have to mix and match. this is all assuming that tokico took into account the correct suspension geometries when they built the sports springs kit
any ideas on a setup for spring rates then? going to have L28ET (240hp) dropped in sometime, and I will be continuing to autox the car, so something fairly stiff, wont be on r-comps, most likely dunlop star specs
PPK was running 550lb/in springs... said he was going to change them out for 800lb ones. Though I don't know if he ever drives his car anywhere other than to In & Out car meets. ooo003oo32h!
A quick Google-machine "serch" brings back tons of peepz saying 400-600lbs for a coil setup.
yep its always broken when I need it; you should this by now
anyway I figured what setup Im going with -- T3 front coilover conversion at 6-7kg/mm and S13 megan track series rears at 10kg/mm
sound good? 'nuff said?
), anyone know what the spring rates on the HPK 255 series kit are?
