83 280zx-prob. w/ auto trans not shifting
Old Dec 30, 2004 | 10:43 AM
HawaiiZ's Avatar
Question 83 280zx-prob. w/ auto trans not shifting
I have a 83 280zx non turbo auto that seems to have a transmission problem of not moving to a higher gear ratio to reduce rpm's. It drives really well, runs great, but just doesn't seem to be working quite right when it comes to the auto tranny. Any easy quick fixes without having to remove tranny?
Old Dec 30, 2004 | 08:17 PM
lww's Avatar
lww
Head Muckraker
The first and cheapest thing to do is verify the fluid level.
After that, a standard AT 'service' with fluid and filter change.
If it has fluid and it's still not building pressure or it's building pressure but not shifting, you probably need a rebuild to replace worn clutches, steels, seals, gaskets, and band.
Old Dec 30, 2004 | 09:15 PM
HawaiiZ's Avatar
Mahalo for the reply and info. will check fluid level and if that does not do it will take in for service.
Old Dec 31, 2004 | 02:21 AM
B1nAryVilE's Avatar
Drain the transmission fluid then pour in some synthetic transmission fluid. If all else fails take it in for a rebuild.
-chuck
Sean Nugent
Apr 15, 2015 08:27 AM
bbvranch
Jun 22, 2011 10:00 AM
PooFlinginMonke
Jun 1, 2011 09:58 AM
xpwarrior
Nov 21, 2010 03:57 PM
supraflymic
Oct 25, 2004 12:35 AM
