zx rearview mirror??
Old May 26, 2005 | 05:25 PM
Castorall's Avatar
does anyone have any idea where i can get a rearview mirror for my 79?? preferably red, but any color will work with some dye...
thanks
Old May 27, 2005 | 03:14 AM
I have a red one but it is faded, and cracked. You could probably fix the small cracks with bondo. Shoot me a price, and we will go from there.
Old May 27, 2005 | 04:06 PM
Mooney's Avatar
I've had issues filling cracks with bondo, cracks always seem to come back, even if you were to mound it up (which in turn looks like ****) if you do go that route use something along the lines of problem plastic first, its a 2 part epoxy that dries rock solid, start sanding it before its completely dry or else you might be there a while and end up with sore fingers. Then you can use glazing putty to get your smooth finish.
Old May 27, 2005 | 04:11 PM
Castorall's Avatar
if i go that way, i'll just do it to my own mirror.
it just looks so bad and lots of other ones do too...i dont know why no one makes em. (that ive come across).
appreciate it tho, that is a good idea
Old May 27, 2005 | 04:51 PM
Hey where can I get this stuff at? What kind of stores, carry it? And it is called problem plastic? I have never heard of it. Is it also good on dashes, and other plastic parts in the interior with cracks? Like also my original door panels?
Old May 27, 2005 | 04:54 PM
Well technically you can buy a new mirror in any factory color you want. But I think it is expensive. Motorsport auto want close to $200, for a rear view miiror for any year 280zx! Their website is zcarparts.com I didn't really want or have that money to do that. So I am going to fix mine and repaint it. My '81 has a red mirror, and my '82 has a silver mirror.
Old May 27, 2005 | 05:29 PM
icice9's Avatar
Super Siver & Black Stud
ive swaped mine out from a Z32 they mount rite up
Old May 27, 2005 | 06:23 PM
Mooney's Avatar
http://www.levineautoparts.com/semprobplasr.html
Theres also a semi-weld in the same packaging, yet doesn't dry solid. Not what you'd want.
Interior parts i'm not too savvy on repair ways. I can tell you the issue you'd have with this stuff right off the bat is the hassle you'd have trying to actually finish it off. I have seen it used on door panels, but it was used as a filler, someone had cut holes for tweaters and next owner decided against them. Something was still used to coat the problem plastic with so that texture could be applied to it. As far as a bonding stuff though, this works great, use it on torn bumpers all the time.
Theres a guy at work that does nothing but interior; I've been meaning to ask him how to go about fixing my dash in my 280zx as its cracked up. One of the cracks going right through the passenger speaker grille, I've seen him do some console repairs, hes able to blend in the texture pretty well. I'll ask him what he uses and get back to you on that one.
Luke
Old May 27, 2005 | 09:44 PM
Dorifto's Avatar
A Z32, eh IceIce? I'll have to try that one.
My mirror's pretty straight Castorall - haven't looked at it in awhile, it's been taken off as well as the rest of my interior. I'll check it out tomorrow and get back to you. Oh, it's faded silver/gray by the way, and to the best of my knowledge, it's straight with no cracks.
Old May 28, 2005 | 02:16 AM
Captain caveman's Avatar
Luke
I have a crack in the exact area too. I'm thinking of just cutting out that whole piece of the dash and install a speaker grill
how would you recreate that leather like texture that's on the patched up spot if you filled in the crack
Old May 28, 2005 | 03:20 AM
Hey thanks for the info Mooney! Yeah defiantely let me know after you talk to your friend.
Old May 28, 2005 | 11:37 AM
jfairladyz's Avatar
I went to adjust my mirror the first day I bought my Z and the damn thing crumbled in my hand. Almost the entire plastic backing fell off. The sun wreaks havoc on these old interiors.
Old May 28, 2005 | 11:51 AM
Yeah it does for sure, especially out here in the Arizona desert!
Old Jun 1, 2005 | 05:45 AM
Mooney's Avatar
Talked to the guy at work, hes truely old school it sounds like. He's going to check out some more info from some other sources. But he told me this way would work well with the high density foam dashes due to flex;
He said using the SEM Semi-Flex weld (which isn't porice at all and once finished should yield smooth results) fill the crack (I'm assuming after v-grooving the area) till its flat. And to obtain texture (This is where the old school thing came into play) he likes to use rocker panel spray/chip guard. And before the spray dries he takes these pads (maybe 2x2 in like a leather type of material) that are textured and blend in the area as well as possible. Then finish off with dye of your choice.
Sounds like more a trial and error process. But definately something to give it a go.
I'll post anything else he says; he was telling me about some Dash Putty too, but it'll crack under flex. Conversation got interrupted by Op's manager, so I'll have to finish that one later.
Hope this helped some.
Z_lover
Oct 18, 2012 10:29 AM
attacksoma
Oct 12, 2010 11:16 AM
stevensane
May 18, 2008 11:40 AM
BeanerZ
Apr 11, 2003 12:17 PM
Zpeed
Jul 20, 2002 11:19 PM
