A few pics of rust repair in spare tire well
Old Jun 30, 2014 | 08:17 PM
GNRick's Avatar
Removed spare tire and found a hole about 3" X 2" around the rubber plug. Cut out all rusted area. Applied POR-15 to the area, then primered and painted it. Glued in a piece of sheet metal from Home Depot. I used emblem adhesive. Put a brick on the patch and held it down with wood shims. Sprayed the bottom side with bed liner as that was all I had. I'll probably just leave the rubber plug off unless someone gives me a good reason to drill a hole in the sheet metal and put one in. Will find out tomorrow if the glue held. If not I'll rivet it on.
Attached Thumbnails A few pics of rust repair in spare tire well-hpim2819.jpg   A few pics of rust repair in spare tire well-hpim2824.jpg   A few pics of rust repair in spare tire well-hpim2828.jpg   A few pics of rust repair in spare tire well-hpim2830.jpg   A few pics of rust repair in spare tire well-hpim2832.jpg
A few pics of rust repair in spare tire well-hpim2833.jpg   A few pics of rust repair in spare tire well-hpim2837.jpg   A few pics of rust repair in spare tire well-hpim2838.jpg
Old Jun 30, 2014 | 08:25 PM
GNRick's Avatar
Battery tray just had some surface rust
Sanded the rust and painted it with POR 15. Sprayed it with some red paint but it didn't seem to cover too well so just called it a day.
Attached Thumbnails A few pics of rust repair in spare tire well-hpim2826.jpg   A few pics of rust repair in spare tire well-hpim2827.jpg   A few pics of rust repair in spare tire well-hpim2829.jpg
Old Jul 8, 2014 | 02:00 PM
The plug is just there to let you drain the water out which as you can imagine from the rusted out hole never happened
Old Jul 8, 2014 | 05:32 PM
GNRick's Avatar
I hope I don't have water leaking in there. There is minimal rust in the hatch area.
Old Jul 8, 2014 | 07:52 PM
zxguy1986's Avatar
Good job. Usually riveting is necessary under the seat wells because of potential further rust and the strength needed - but you're probably OK under the wheel well as long as you coated it good. You saved a pain by avoiding the drilling and riveting. Maybe add another coat or two on the underside of your patch. If your hatch area has leaks, water will collect in the bottom of that well - so you still should have a drain.
Old Jul 8, 2014 | 08:09 PM
borini63's Avatar
There is a good write up about how to fix the spare tire well.....
Spare Tire Well Replacement (and pics!) - Nissan : Datsun ZCar forum :Nissan Z Forum: 240Z to 370Z
Old Jul 8, 2014 | 09:14 PM
GNRick's Avatar
Yes I read that write up. That is what motivated me to do my little patch work. The patch didn't conform to the hole as well as I would have liked, so I siliconed around the patch from the inside and outside for extra insurance against water splashing in from the outside. I'll keep an eye on it for water collecting in there if I ever get caught in the rain (or when I wash it).
ViperGTO99
May 12, 2024 05:44 PM
NuBeeZee
Jul 26, 2014 06:54 AM
LikeZcars
May 30, 2011 04:29 PM
BlueKitsune
Jul 16, 2009 11:06 PM
DGriffin
25
Nov 2, 2006 11:49 AM
