Are Dash Covers Any Good?
Old Aug 24, 2003 | 03:22 PM
icice9's Avatar
Super Siver & Black Stud
im using one of those dash caps on my car too.. its actually not that bad... from first glance you wouldnt know it was a cap.. but it did take a lil work to get it to fit on right... i had to trim off some of the origional dash to get it to fit tight.. but it came out looking really good.. its a simple solution till you do find a replacemnt dash..
Old Aug 29, 2003 | 08:39 AM
cerealkilla's Avatar
my first 280zx had a plastic cover like the one you are describing and the only problem that i had with it was where the stock dash was cracked, i never properly prepared it for the cap. if you just stick a cover over severe cracks w/o prep eventually the cover will crack too, especicaly if you live in a hot climate. reason being where the dash is cracked the foam will expand and the crack will grow upward right through your cap. take a razor blade and carefully cut about 1/2 inch to the sides of the crack, then fill it with r.t.v. (silicone sealant). let this cure and you are ready for your "new dash". good luck
Old Aug 29, 2003 | 12:01 PM
roger that, good luck.
Lovenpain
Aug 2, 2021 06:27 AM
marcello129
May 12, 2005 04:17 AM
legalian
Dec 22, 2003 06:25 PM
bigkahoona101
Jul 24, 2002 01:20 PM
kdow
Apr 14, 2002 01:41 PM
