Body kits
Old May 6, 2007 | 03:12 PM
wgc_3's Avatar
Body kits
Ok so I am thinking Im going to change the paint on my car, and put a body kit on it.
The only body kit I've seen is Shady's and I haven't seen where to purchase it.
So Shady if you could answer that question would be great.
Has anyone seen one that really stands out to them?
Also, what is the best way to remove all the paint on the car?
wgc_3
Old May 6, 2007 | 03:17 PM
turboboost's Avatar
I'm quite sure Shady's is custom made.
One kit you might want to look into is the MSA type II.
Old May 6, 2007 | 03:20 PM
wgc_3's Avatar
Thank you, anything else you have in mind?
I do, but I don't like the wing, but you can't even purchase it anylonger.
http://www.thezstore.com/page/TZS/PROD/7AP1/50-1512G
wgc_3
Old May 6, 2007 | 03:27 PM
^ The wing never was included with the kit. Just in case you don't know. Me personally I think the F-40 wing is the best looking on the 280zx's. That is my opinion though. And of course the whale tail is pretty sweet also. I will probably go with the type 2 kit, or something similiar later on.
Oh yeah as for the paint. Either sandblast it off, which you would have to be careful. Or sand it starting with 80 grit I believe. Then work on down to 60 and so on. If you are wanting to sand to the metal. If not I believe 80 grit is a good start to rough it up. So the primer will stick, and then you can sand that with a higher number grit, to rough that up. And after that, you can put the paint you want on the car. I am no expert, but this is what I know from messing around with my cars. And finding info on here. Hope it helps you out man.
Old May 6, 2007 | 03:35 PM
wgc_3's Avatar
When I had the paint done on my Corvette I used a putty knife to take off the paint, but I don't know if you can do this to metal?
wgc_3
Thank you for the feedback.
Old May 6, 2007 | 03:39 PM
^ You might be able to do that. But you would probably want to sand it real good, after you use the knife. Otherwise I don't see why it wouldn't work. Just do it as evenly as you can. And it should be allright. I am sure there are some better people, that could help you better. I don't know a lot, but I like to share what little I do know.
Old May 6, 2007 | 03:42 PM
wgc_3's Avatar
I do value your input thank you! I still have to get the damn thing running, and then move it to CO, this is just a festering thought I've had for a while figured I'd run it down with yall.
Color Options-
Black- Water spots to easy
Red- Sounds good just sucks when chipped
White- Too much dirt
Yellow- Not so much
I'm thinking of GM's new color on the Corvettes thats a brushed grey/titanium.
Give your input.
Thanks,
wgc_3
Old May 6, 2007 | 06:13 PM
3XAZOWNER's Avatar
Originally Posted by wgc_3
Color Options-
Yellow- Not so much
I painted my hood black and wash it weekly, and I havent had a problem with waterspots, like I thought I would. I use THE ABSORBER to dry it with. Do not get a "Works Like Absorber" cloth, but get the real one from WalMart or a parts store. Now instead of Datsun black, i used Hummer black (which has blue in it to make it black black and not have a brown tint in it, like some do) and clearcoated it with a clearcoat that was $185 a gallon and i think that made the difference. I love the black, but you better have good a/c cause it will get hot. Good luck and hope it turns out good. I changed my color many times before I finally spent the money and bought the paint. I went and looked at peoples z's on cardomain trying to decide on a color.
Old May 6, 2007 | 08:29 PM
hehe, yeah mine is custom, it helps to be a aircraft structures tech. having all the metal tools is a plus. the front airdam is a 8' by 12" piece of .040" aluminum, and the sides are custom steel formed, and welded on the car. the original was rotted off, so i figured good time to put my handy work to use. thanks for the compliment for the body kit, if you want more pix, i will gladly post them. think i even scan some of my original pix from when i was making it. oh, and the rear spoiler is just a msa low pro whale tail. any more info, just ask. you could always make a clone.
Old May 7, 2007 | 07:11 AM
wgc_3's Avatar
Problem is I really don't have the tools needed to bend metal like like. What did you use an english wheel of some sort?
I would like to see your wheels at a close up from the pic you have your car is deff. unique, and just well awesome to say the least.
Thanks,
wgc_3
Old May 7, 2007 | 07:15 AM
wgc_3's Avatar
Problem is where I live in Northern CO, within a change of a ferw hours it can go from 60 to 20+snow back to 60. And if I had black I know it would water spot being its my primary car. Also, you cleared it your self! I would have to get someone to do the priming/painting/clearing because when I get it running and moved to CO I have no where to paint in.
If anyone knows a good painter in CO let me know please.
Do you really feel that $185/pg was worth the clear?
Thanks for the input btw,
wgc_3
Old May 8, 2007 | 06:47 AM
here ya go, everyone knows these pix, right when i first got them.
and one with stock rims, looks aight still
Old May 10, 2007 | 10:16 PM
duckyz's Avatar
I like the MSA I kit...
http://www.thezstore.com/page/TZS/PROD/7AP1/50-1505G
Old May 11, 2007 | 07:28 PM
wgc_3's Avatar
Damn good looking. Impressive handy work.
Old May 13, 2007 | 09:47 PM
wgc_3's Avatar
I would do dirty dirty things to your car!!!
Old May 15, 2007 | 06:28 AM
007max's Avatar
From NY to AZ
Here's another option.
Old May 15, 2007 | 05:44 PM
n00blar's Avatar
Doesn't BlackDragon.com have some body kits for sale as well?
ZZZgirlZZZ
350Z Apperance Exterior, Interior
Dec 30, 2007 11:10 PM
kookymonkey69
Aug 28, 2005 12:28 AM
myjadezxt
17
Oct 29, 2004 08:47 AM
Zmann
Jul 13, 2004 02:15 PM
Medium
Aug 13, 2001 01:04 PM
