ZWheels Sizes
Guest
Posts: n/a
Re: ZWheels Sizes
17" should fit with no mods but it also depends on how wide you want them.
spacers are for wheels that have a different offset, which would cause the wheels to hit the suspension.
if you dont mind spending a bit of money look at the simmons range of wheels, they make them to suit your car.the attached picture is the LE series
hope this helped
later
jeremy
hope this helped
later
jeremy
Guest
Posts: n/a
Re: ZWheels Sizes
What are the chances that are rims are the same bolt pattern as Hondas?
Bill
77 280Z
www.dsetuning.com
Bill
77 280Z
www.dsetuning.com
Guest
Posts: n/a
Re: ZWheels Sizes
ZERO hondas use the smaller 4 lug if you want other new cars try the regular mustangs or the new sentra SE-R spec-v i'm currently buying a set of ICW five stars for a mustang there 30mm offset so i have to have a spacer but i hope that helps.
when the guy in the car next to you sees you grin he'll find out why at the line
76' 280
76' 280
