weird request.
Old May 29, 2002 | 09:57 PM
zguy36's Avatar
Dead
Re: weird request.
just curious, but what is the fuel injection doing that is giving you problems?
-jeremy-
Old May 30, 2002 | 09:31 PM
zguy36's Avatar
Dead
Re: weird request.
I have chased a lot of problems with my injection too. The best luck I have had is with cleaning the computer terminals. Clean those and the connectors and that might help.
-jeremy-
Old May 30, 2002 | 10:10 PM
lifegrddude's Avatar
Externally Wastegated
Re: weird request.
What have checked on your diagnosis? The AFM, TPS, coil wires, spark plug wires, plugs, loose connectors in the engine bay, oil pressure readings, compression check, and several other things are culprits that could make your car run bad. I had the same problem, and it turned out to be a couple of things: 1. The wires going to the ignition coil were so old that the bends in the wires were pinching it so that little voltage was going to the coil. 2. A minor oil leak due to a bad oil return tube gasket had caused my oil pressure to go low and make the car sputter. 3. Old plug wires with a bad connection to the plugs was causing misfire and hesitation. Those were the main three that were the problems I had, I hope that helps you out some. I had some other minor fixes, but those again were my biggest ones. Good luck with solving the problem.
82ZXT
Jennings.brent6
May 30, 2014 11:10 PM
speed280zx
Oct 23, 2008 09:16 PM
s/cL3.0
Mar 1, 2007 02:02 PM
LUCKYZ
Dec 1, 2006 08:46 AM
s/cL3.0
Oct 18, 2005 09:00 PM
