VG30 into 280zx
Guest
Posts: n/a
Re: VG30 into 280zx
If youare looking for power, why not just drop a 350 in. It is a muchmore popular swap and there are kits already available to help. for more info visit www.jagsthatrun.com
Guest
Posts: n/a
Re: VG30 into 280zx
Well sorry not much info I can offer, you are pretty much on your own since its not a well documented swap. I do sortof wonder why you want to go with the VG30 over the L28. The only advantage I can see is slightly lighter weight, as well as distribution towards the center of the car more. As far as power goes, you are no furthur ahead as far as I know.
Either way, good luck and try to document the swap as well as you can for the next person to try it!
Guest
Posts: n/a
Re: VG30 into 280zx
if you are going witha tt vg30 then you are gonna have space limitations......has been done but it is tight, i was gonna do a tt vg30 swap into my 240, but decided against it. too many hassles...for not enough power gain. i also looked into doing a rb26dett swap....but donor motors are too expensive...as of right now it looks like it will be a sbe/t-5 swap.....goood luck with yours.
