Under coatings
Guest
Posts: n/a
Under coatings
I was thinking about having the bottom of my 78 coated with rhino bed lining coating. that stuff works great in a truck bed so I was thinking if I used it for a undrcoating/ rust preventer.it should work great. Other benefits are sound deadening properties and I would never have to worry about rust or undercoating my car again.
Let me know what you think I am curios if this sounds like a good idea
Shane Morton 78 280Z owner.
Z me go - Z me show - Z me gone
Guest
Posts: n/a
Re: Under coatings
I think it is a GREAT idea. I Just got a 240Z and I was thing of doing it also, I also want to do the inside floor pans etc.. Let me know how it works out ggaffney@optonline.net
Guest
Posts: n/a
Re: Under coatings
To Shane and all other posters to this question--------this is a good product---------yes it is strong and capable of a good shelf life on your car----------But for every good thing there is a bad thing-----------This product you plan on using on the bottom side of your car is intended to be used on top of paint----not undercoating--------and to be honest you must have a good paint job to expect the bedliner coating to last---------so to get the the bottom of this all-----------to Undercoat your 240Z with this rhino coating or any other bedliner coating you will need to strip off all material from the bottom of your Z right down to the bear metal---than you would have to metal-etch prime the stripped metal----than paint it with a basic urethane paint-------than apply the bedliner coating-----just some insight
Remember you must have a solid foundation for longevity
LaterZ, 81 TURBO
LaterZ, 81 TURBO
