Turn Signals Problem
Guest
Posts: n/a
my hazards work, but when i use my signals nothing works at all...they worked before i took out the middle part where the shifter boot an arm rest are and since i put it back on it hasnt worked sence...does anyone know where to trouble shoot..i dont think its the signal lever...im stumped
FASTLANECRX@AOL.COM
please exscuse the lame email address...
FASTLANECRX@AOL.COM
Guest
Posts: n/a
Re: Turn Signals Problem
The turn signal circuit is disabled by the hazard switch. Check your connector from the console into the main harness on the passenger (right) side of the console - I just found my connector was all corroded there and I had the same problem with my turn signals.
'78ZXT
'78ZXT
Guest
Posts: n/a
I had a similar problem with my 76 280z. The flashers would work, but the turn signal would not. I noticed there was a broken wire on the turn signal switch. I resoldered the wire and wrapped all of them in cherry tape. Ever since then my turn signals have worked like a charm. I hope that this helps.
