Turn Signals Problem
my hazards work, but when i use my signals nothing works at all...they worked before i took out the middle part where the shifter boot an arm rest are and since i put it back on it hasnt worked sence...does anyone know where to trouble shoot..i dont think its the signal lever...im stumped
FASTLANECRX@AOL.COM please exscuse the lame email address... |
Re: Turn Signals Problem
check that you did put all the wires back correctly....
i wouldn't think that it would be a short or something |
The turn signal circuit is disabled by the hazard switch. Check your connector from the console into the main harness on the passenger (right) side of the console - I just found my connector was all corroded there and I had the same problem with my turn signals.
'78ZXT |
I had a similar problem with my 76 280z. The flashers would work, but the turn signal would not. I noticed there was a broken wire on the turn signal switch. I resoldered the wire and wrapped all of them in cherry tape. Ever since then my turn signals have worked like a charm. I hope that this helps.
