tires/wheels purchase help!
Old Oct 14, 2002 | 05:47 AM
1tuffz's Avatar
Re: tires/wheels purchase help!
with the stock struts i believe u will be limited to approx. 7" wheel width. if you go to coilovers you can stuff up to 8.5" or even 9" wheels under stock fenders. the z is a 4 lug, bolt pattern 4x4.5" [same as the old L6 810/maxima, toy ota cressida and celica, and some others i don't know about]. as far as 17's, seems those would be a bit tight without coilovers. i'm running 17x8.5's with a 235/40/17 tire. the plus one conversion for the z is a 15x7" wheel and 25/60/15 tire. you can call tirerack for plus 2 [16"]or 3 [17"] conversion size info. i purchased my wheels from motorsport specialities in pa-and they were great.
check them out at; www.usacomp.com
i have the ps-1's
David
1TuffZ
zccr.net
Old Oct 14, 2002 | 02:40 PM
Spudz's Avatar
Gerry ,
The ZX and the Z have different suspensions and wheel
wells in them. I don't think the 17's fit well without mods
like coil overs to clear the spring perch.
Mike
Old Oct 17, 2002 | 01:38 PM
Here is a great wheel/tire calculator. Put in 195/70/14 as the stock tire size for the 240Z. (correct me if I'm wrong) and then put in 16 or 17 inch on the custom rim size and see what you need for a tire. Weather it will actually clear your suspension is your own problem, this is just for tire sizes! :-)
http://www.miata.net/garage/tirecalc.html
BoulderZ
Nov 19, 2007 07:55 AM
NismoVega
FS: 300ZX (90-96)
Nov 7, 2006 06:27 PM
rob209
Oct 12, 2006 02:03 PM
mlov
FS: 300ZX (90-96)
Aug 25, 2006 01:25 PM
BL929RR
Feb 2, 2002 07:36 PM
