Suspension work....
Old May 18, 2002 | 01:27 PM
auxilary's Avatar
the Dude
Re: Suspension work....
don't get the compressors from MSA - they rip you off on those. They charge $30 for a pair of compressors you can buy from www.harborfreight.com (harbor freight tools) for $10 (per pair). I should know, I made that mistake - they're the exact same make and model number. Here's the link:
http://www.harborfreight.com/cpi/cta...temnumber=3980
If you're planning on doing coilovers, be sure to select the right spring rate. I am running a combo of ground control coilovers with 200lb/in springs and tokiko 5 way struts. At level setting 3 on tokikos, daily driving is almost unbearable. For more practical application, i'd recomment 150 front 175 lb rear springs. Also, for coilover install, you'll need to grind off the lower spring perches and weld in coilover rings that hold the sleeves. If you're interested, I kept a photo log of what I've done with my suspension, you can see it here:
http://www.imagestation.com/album/pi...?id=4292135809
Old May 19, 2002 | 08:22 PM
auxilary's Avatar
the Dude
spring manufacturer shouldn't matter: it depends on what spring rates you choose. 600lb/in on the street on tokikos will be unbearable and you'll wish for a new prostate!
Old May 19, 2002 | 08:36 PM
Skully's Avatar
hahah mine are stock ones from '81 still and they feel like that SOOOO STIFFF
my mom hates it when i drive her in the car shes used to a newer more quiet one
wooohooo done done finaly done
Cyproz
May 5, 2014 07:59 AM
skittle
15
Aug 28, 2008 02:10 PM
moelll
Other Cars
Feb 6, 2006 11:10 PM
efrain
Oct 13, 2005 11:19 AM
zztopp
Jun 30, 2005 09:44 AM
