Strut Brace
Can front strut braces be installed on a 79 zx? I've seen a lot of installations on z's throughout this site, and I thought I could fabricate my own, but when I tried to pre-fit a piece of 3/4" square tube across the towers I couldn't close the hood.
I don't want to notch the inside of the hood, and it looks like I would be defeating the purpose of the brace if I had to put bends in it. What's the solution? |
Re: Strut Brace
Make rings that go around the bolt pattern and drill them to fit. Then weld your brace onto the bottom inside edge.
https://www.zdriver.com/rides/spec/p..._994541134.jpg http://www.zipcon.net/bleach/pages/zcar/zlogo.jpg |
Re: Strut Brace
You could also use a stock front sway bar by attaching plate ends to bolt up to your strut.
https://www.zdriver.com/rides/spec/p...1023822436.jpg |
Re: Strut Brace
Re: Strut Brace
Here is one for the Rear that I made for my ZX.. Seems to work great..
https://www.zdriver.com/rides/detail...x=2&vehId=1265 83Zwigen |
