Still having 76 280z trans probs... please help
Old 01-29-2004, 07:22 PM
I have a present for you...
theramz's Avatar
it still sounds like your clutch is bad, but whether it's your clutch or trans the trans has to come out. Might as well put in a 5 speed if the trans is bad. A 5 speed up to 83' will bolt right in.
theramz is offline
Old 01-30-2004, 08:00 AM
For some reason I think the mechanics you spoke to are not on the right track...
So, its basically like the clutch never engages at all. With the engine running you can go through the gears without ever pressing the clutch pedal down, correct?
So maybe just something happened to the clutch slave cylinder. Maybe there was a problem before or a previous owner had adjusted the clutch pedal arm forward to make up for some air in the clutch master cylinder... now that you bled the system the slave cylinder is out too far and not totally releasin the fork inside the tranmission. I say look into that more. Look at the adjustments on the pedal itself and make sure you're allowing the master cylinder to be fully disengaged. I did some work on a friend's 280Z recently like this.
Bleach is offline
jthiani
12-07-2013 05:55 PM
rjc280z
05-27-2011 10:48 PM
Z-er
01-24-2004 05:11 AM
Bert
15
11-23-2003 09:05 AM
denny41168
05-15-2003 07:34 PM
Quick Reply: Still having 76 280z trans probs... please help
