steering shimmy
Old Aug 13, 2002 | 10:02 AM
Skully's Avatar
Re: steering shimmy
ok mine does this : at high speeds it shakes for bout 5 seconds then stops then shakes after ike 5 seconds again ??
Old Aug 13, 2002 | 10:03 AM
Skully's Avatar
Re: steering shimmy
did u check ur tires cuz a tire can have a plump on it somwhere on the inside causing it to do that......
Old Aug 13, 2002 | 11:11 AM
Skully's Avatar
Re: steering shimmy
well mine jus shakes like every 5 seconds i dont know whats wrong what should i check??
Old Aug 13, 2002 | 12:04 PM
Re: steering shimmy
On my car, it has a very suddle shimmy that suddenly gets stronger with a slight press of the brake pedal. Of course, I know my front rotors are a little warped. Do you think that might be a cause on your car?
Also, if your sway bar bushings are shot, then a little bump in the road may start a shake in your front end that lasts for a few seconds and comes back later. My 280ZX used to do that untill I put new urethane swap bar bushings on front and rear. Tie rod ends can be loose, also the steering rack itself has bushings that hold it down. Be sure those are not totally loose.
Old Aug 13, 2002 | 12:10 PM
Skully's Avatar
Re: steering shimmy
ok ball joints anything else?
Old Aug 14, 2002 | 11:13 AM
Re: steering shimmy
I don't know how hard it is. I have ONLY worked on my Z's front sway bar. well, and my Datsun 620 which is very easy. I think this is like any other car with coil springs. A RWD car has less on the front end than a FWD car of course. The Z's sway bar was a little tricky at one point. You have to really squeeze the bar down to get the last bushing and nut on the top of your end link.
As far as replacing springs or struts... I've never done it, but I really need to soon. My rear springs are saging and the rear struts are a little bouncy. Soon I hope to get some 1 inch lowering springs that are tighter and then buy some new struts all around. That should tighten it up enough for me.
Dr_Nic_T61
13
Oct 4, 2016 12:05 AM
300inCanada
Jun 12, 2003 07:32 PM
albow2213
Jun 7, 2002 11:13 PM
chris
May 31, 2002 02:53 PM
Jammer
May 6, 2001 06:44 AM
