Sluggish motor at 2200 RPM
Old Jun 11, 2002 | 10:39 PM
lifegrddude's Avatar
Externally Wastegated
Re: Sluggish motor at 2200 RPM
Change the fuel filter if it hasn't been changed yet. If you take a hose and put it next to the fuel injectors while the car is running, you can hear to see if each one is working or not. Your fuel pump might not be good. It's located in the right rear wheel well behind a plastic panel that is held by 4 or 5 screws. Good luck.
82ZXT
Old Jun 12, 2002 | 08:47 PM
zguy36's Avatar
Dead
Go buy some TV tuner cleaner from Radio Shack and clean your airflow meter with it. It probably has a "dead" spot in the meter and is making it go way lean. I had this same problem with mine, and cleaning the AFM cleared it all up.
-jeremy-
Pez
Jul 19, 2014 03:57 PM
PoopSmith
Aug 3, 2006 03:36 PM
81s280zx
Jun 25, 2005 04:02 PM
blu300zx
Dec 3, 2004 10:40 AM
