relase clutch and engine dies
Old May 8, 2003 | 09:07 PM
theramz's Avatar
I have a present for you...
I think you might have a short or loose connection in your wiring harness under the steering wheel. Since it runs until you release the clutch, it must be affected by the linkage under the dash. You might try unpluging each harness you can and spraying contact cleaner (from Radio Shack) on them. Disconnect the battery because the cleaner is flammable, a spark could catch you and your car on fire. These old cars get corosion on the contact pins which also causes increased resistance which is why so many fuse blocks are melted. People solve there blown fuse problems by putting in bigger fuses, not safe for the system. Let me know how you make out.
Tom
jgw2205
Apr 3, 2009 04:10 PM
mrelegal1
Nov 2, 2005 06:30 PM
stemo76
Sep 14, 2005 08:47 AM
b300z
32
Aug 25, 2004 08:28 AM
vasago
May 10, 2004 03:21 AM
