Hi, I'm trying to determine if my oil pressure gauge reads normally or is on its way out. It reads normal to low pressure while I am driving (1978 Datsun 280Z) but goes below zero on the highway. It promptly jumps up to about normal when I exit off the highway. Ideas?
Re: Reading oil pressure gauge
The pressure reading should be approximately 60 while running on the highway at higher rpms. Idle the pressure drops to the 20-30 range. Sounds like you have a bad sender unit, or a dirty one at least.
