78 280Z speedo
Guest
Posts: n/a
Re: 78 280Z speedo
Have you changed your diff or tires to a size that is non-stock? I found that my tires, from one brand to another changed my speedo by over 5%, and I changed my diff, so the other 5% was expected... maybe the brand of tires you use have a smaller sidewall than stock? Or you're running aftermarket wheels?
The Beast is back and badder than ever!
Guest
Posts: n/a
Re: 78 280Z speedo
I do not know about the different colored pins. I bought this car about 4 months ago, and I think it has the original differential. It definately has the correct tire size...but has 14x7 wheels, which would reduce the overall diamter slightly...would it do it that much?
Guest
Posts: n/a
Re: 78 280Z speedo
If your tire is narrower, then it will affect the overall circumference of the tire/wheel. You can correct this by finding the correct color drive gear for your speedo like Amber mentioned... so if you're running say 185-60-14 rather than 205-60-14, then it doe make a difference, just an example.
