RB30 ENGINE IN A 260z
Guest
Posts: n/a
Re: RB30 ENGINE IN A 260z
Is that an old 'Creations' manifold on your car?. I've got one just like it, well apart from the custom plenum & aluminised coating...
Anyhow, yes you will need the RB gearbox & mounts & a modified sump, and lots of other things.
My dad's in the process of putting an RB25DE into one of our 240Z's but the actual fitting of the engine is quite a way off yet.
Which capital city are you nearest to?
Ben
Adelaide,
South Australia
Ben
Adelaide,
South Australia
Guest
Posts: n/a
I have a rb26 in mine. the block is the same just a little taller. you can either custom make all mounts and driveshaft or you can use rb-20 eng mounts from the Z-31 (japan spec) use teh r-33 gtst tranny and front 1/2 of the driveshaft and the only mount you have to make is the tranny mount.
If you use a rb25 grab the oil pickup and pan from the z-31 rb20 and it is a bolt in mod!!!! Ive been told austrailia didnt get the rb20 z-31 so that may be a problem.
my 2 cents
my 2 cents
Guest
Posts: n/a
I've never seen a turbocharged,carburetor set up in a Z before, that's pretty wierd looking. Also just curious, why are there so many Aussies on this board? Is it based in Australia?
Joey
1976 280Z 2+2
2+2s are not ugly
Joey
1976 280Z 2+2
2+2s are not ugly
Guest
Posts: n/a
its based in america... but we aussies just love our Z's
<font color=blue>76 260z</font color=blue>
The NiteRider
The NiteRider
Guest
Posts: n/a
I don't think so - the 200ZR has a different x-member & mounts & they're the ones you need. Perhaps the Laurel or Stagea mounts would work, but your guess is as good as mine.
Not that it's critical here in AUS - I could list 1/2 dozen workshops in each city that could fit an RB to a Z. There's plenty of local knowledge here.
Ben
Adelaide,
South Australia
Ben
Adelaide,
South Australia
Guest
Posts: n/a
IF your going to sell ur turbo setup when u put in a RB, i"ll buy it from ya...
The NiteRider
The NiteRider
Guest
Posts: n/a
If you did that, I'd STRONGLY recommend the use of a TBI setup over the carbs. Perhaps something like a single 45DCOE-style throttle body unit with big injectors.
Converting one of the 'creations' manifolds to MPI is a pain (been there, done that)...
Ben
Adelaide
Sth Australia
IZCC#1902
240Z L31ETT
L28ET MR30 Skyline
FJ20DET DR30 Skyline RS-X
Ben
Adelaide
Sth Australia
IZCC#1902
240Z L31ETT
L28ET MR30 Skyline
Guest
Posts: n/a
Rb30 is out a a holden vl commodore, and the R31 skyline, the RB is the better version of the L28...
Rb's are out of skylines
The NiteRider
The NiteRider
spencer.m.mille
Jun 30, 2012 06:51 AM
kewlcat187
Sep 20, 2002 01:03 AM
