q. for adj. tokico adjustable users!!
Guest
Posts: n/a
Just read saw an artice in Options, and they have the electronic damping force controller that allows you to adjust the firmness of the shocks from inside the cabin electronically!! I already called them to see if they had anything for the tokicos but nada. Anybody know of something else??
thanks,
franklin
http://www.netsnapshot.com/pickalbum?zpeedrazer
thanks,
franklin
Guest
Posts: n/a
Re: q. for adj. tokico adjustable users!!
Unless you are on a race track and need to adjust for changing conditions, I am not sure what benefit a street car would get for the expense.
Scottie
GN-Z/Vette IRS
10.92 @ 126.08
Scottie
GN-Z/Vette IRS
10.92 @ 126.08
Guest
Posts: n/a
one word... lazy lol truly in all honesty id use it when im at a stop light and dont have enough time to get out and adjust them. Oh yeah by the way congrats on breaking into the 10's!!
thanks,
franklin
thanks,
franklin
Guest
Posts: n/a
Lazy. I did not want to say it, LOL.
Thanks for the kind words.
Scottie
GN-Z/Vette IRS
10.92 @ 126.08
Scottie
GN-Z/Vette IRS
10.92 @ 126.08
Guest
Posts: n/a
By the way, know of any place to get a quaife lsd for an r200 cheap?? Im still saving up to do the rear-end and i just got my parts back from jet-hot so im digging in the sofa for extra moolah. Found out modern-motorsports was selling them for dirt-cheap but they were for the wrong one or something??
thanks,
franklin
thanks,
franklin
Guest
Posts: n/a
If you are a little patient, guys over at hybridz are working on a kit to swap in the R230 which should be plentiful because they were available in so many Nissans and have LSD.
Scottie
GN-Z/Vette IRS
10.92 @ 126.08
Scottie
GN-Z/Vette IRS
10.92 @ 126.08
Guest
Posts: n/a
But it doesnt have to be checked out like every other month or so does it?? 1200 bucks and i get a life time warranty even if raced.. but thats still a pretty penny. How far along are they with it??
thanks,
franklin
thanks,
franklin
Guest
Posts: n/a
Hi
Hey scottie do you know what the weight difference is between the r230 and r200. Ive heard that the rear gear ratio is below 3.5 and more suited to a torquey V8. would it be practical for a mild, early z.
Toronto Ontario
Toronto Ontario
Guest
Posts: n/a
I had a Toyota 4x4 p/u that I had a bunch of rancho suspention stuff on including the RS 9000 shocks, you can adjust them from right there in the cabin. It was sweet for when your out wheelin and bouncing around, good for the hwy too. That and it was just trick to be able to screw with your settings while driving. I think I saw some bilstine's or koni's with that option somewhere for Z's
What turns? There all straight to my Z
Guest
Posts: n/a
The R200 is a 8" ring gear and the R230 is a 9" ring gear, yeah, 9" just like the famous Ford 9". As a result, you expect it to be heavier but the diff is much shorter than the R200 so the weight difference mught not be as bad as expected. If you have the kind of HP that needs a R230, that extra weight means nothing.
The average built up L28ET is just fine with the R200 but if you want a LSD, you are limited to big bucks for a Quaife or trying to find the elusive 300ZXT 3.70 LSD. The R230 LSD is in several Nissans with 3.54 being the lowest (highest ratio).
Scottie
GN-Z/Vette IRS
10.92 @ 126.08
Scottie
GN-Z/Vette IRS
10.92 @ 126.08
PurePontiacKid
Dec 15, 2011 09:16 AM
guycali
Oct 9, 2004 08:59 PM
guycali
Oct 9, 2004 08:58 PM
gtplus2
Apr 17, 2004 09:12 AM
