ZDriver.com
-   240Z, 260Z, 280Z (S30) Forums (https://www.zdriver.com/forums/240z-260z-280z-s30-forums-9/)
-   -   pull the engine to change oilpan gaskett?!!! (https://www.zdriver.com/forums/240z-260z-280z-s30-forums-9/pull-engine-change-oilpan-gaskett-2666/)
wickedshadowz Jul 23, 2002 06:40 AM
I got a Haynes manual, it says you have to lift the engine a little to take out the oilpan. PLEASE TELL ME IT AIN'T SO!!!!!!
wickedshadowz[img]/w3timages/icons/crazy.gif[/img]
Zpeed Jul 23, 2002 10:14 AM
Re: pull the engine to change oilpan gaskett?!!!
u don't i;ve done it with the engine bolted in, just need a little bit of manuvaring...
the manual says it cause it is really easy to get out once u lifted it up 1 inche or so... if u can't be bothred don't worry.. if u can be do it its easyier... espcially to clean the bottom of the block for prepping for the new gasket
<font color=blue>76 260z</font color=blue>
The NiteRider
mar2c_78_280 Jul 28, 2002 09:19 AM
i replaced the oil pan gasket on my 78 280 w/o pulling the motor. it takes some maneuvering, but it can be done. plan on knocking your knuckles alot !!
Tony Martucci
78 280
http://www.geocities.com/mar2c/280z.html
