OK now the engine is poping gas out the carbs????
Old Mar 23, 2003 | 08:18 AM
Creator's Avatar
Ugh, does yours always do that? or only at a certain RPM? or only at certain speeds?
Mine pops out of the carbs when its cold, and i rev it over 3500rpm, i've tried almost everything to get it fixed. but i think its cuz im running too lean.
Give us smore information and we may be able to help you out.
.cre
Old Mar 24, 2003 | 06:40 AM
Creator's Avatar
is there an article or website that describes how to 'sync' yer carbs? i got a pair of SU's on my 260z (which is the one thats coughin' through the carbs aswell). I dont think my timings off, since it just started to do this out of the blue.
.creator
Old Mar 25, 2003 | 06:59 AM
Creator's Avatar
hrmm once i take my 260 outta storage, i'll have to check that out.
.cre
Old Mar 26, 2003 | 07:01 AM
Creator's Avatar
yup, i rebuilt mine when they started popping, with no change after (although it did idle a bit better), but the popping still happened after 3500rpm (mostly though, it only happens in 5th gear, which is wierd).
but yeah, im sure its a fuel problem. im prolly gonna upgrade my fuel pump to a holly blue pump later on, see if that fixes it up.
.cre
Old Mar 31, 2003 | 11:40 AM
Creator's Avatar
George, did you opt for the Regulator on the Holly Blue pump? if i was gonna get one, i'd want to be able to use a remote regulator (located in the passenger compartment, for easy adjusting while driving).
Do you know of anything that could be used for that?
Also, where did you get yer blue pump? i called performance improvements and they quoted 170$cad (pretty high if you ask me). i was curious if there was any other performance shops that have good deals
Thanks
.cre
Old Apr 1, 2003 | 10:20 AM
Creator's Avatar
yeah thats exactly what mine does, 5th gear, 3500+rpm (keep in mind, im doing 110mph at that rpm). Once i can get some cash together, the Holly Blue pump will be my next purchase, to see if i can push it to 120 or higher.
.cre
Old Apr 2, 2003 | 10:34 AM
Creator's Avatar
George, Where are you located? If yer willing to help i wouldn't mind swinging by so we can look at my carbs together, cuz i've been doing alot of reading about the SU's and first thing that most of the documentation says is "LEAVE THE CARBS ALONE IF YOUR UNSURE WHAT THE PROBLEM IS" heh. Since apparently Timing/ignition play a HUGE role in determining carburation problems with the SU's.
Let me know, im in Mississauga/Toronto/Northyork all the time.
thanks
.cre
Old Apr 4, 2003 | 09:37 AM
Creator's Avatar
Sweet. once this crappy weather improves i'll give them a ring, and swing by, since its practically on the way to work.
Thanks
.cre
